Beam Design - 1920
Grade: SP No.1
Design Span (L): 15.00 ft.
Clear Span: 14.00 ft.
Total Span: 16.00 ft.
Bearing (lb): 12 in.
Selfweight: 131.2 lbs
Dist. Selfweight: 8.75 plf
Total Weight: 140.0 lbs
Notes: Double 2x12 at 8ft on Center. 2x6 Joists at 12 inches on center. Upper Floor Support.
Beam Design Dennis Langat 1920
3/12/2022 1
3/12/2022 2
Volumetotal = N[A x (L + lb)] = 2 x [16.88 x (180.00 + 12)] x (12 in./ft.)3 = 3.75 ft3
Volumespan = N[A x L] = 2 x [16.88 x 180.00] x (12 in./ft.)3 = 3.52 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 3.75 = 140.0 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 3.52 = 131.2 lbs
ws = 8.75 plf
15.00 ft.
1469.99 lbs
1469.99 lbs
3/12/2022 3
fb = = 980.0 psi
 fb = 980.0 psi < Fbx' = 1150.0 psi  (CSI = 0.85)   ➜  OK
3/12/2022 4
fv* = = 53.59 psi
 fv* = 53.59 psi < Fvx' = 201.25 psi  (CSI = 0.27)   ➜  OK
fv = = 61.25 psi
 fv = 61.25 psi < Fvx' = 201.25 psi  (CSI = 0.30)   ➜  OK
3/12/2022 5
ΔLL = = 0.20 in.
(L/d)LL = 180.00 / 0.20 = 900
 ΔLL = 0.20 in = L/900 < L/360   ➜  OK
ΔTL = = 0.37 in.
(L/d)TL = 180.00 / 0.37 = 490
 ΔTL = 0.37 in = L/490 < L/240   ➜  OK
Ab = b x lb = 1.5 x 12 = 18.00 in2
fc⊥ = = 40.8 psi
 fc⊥ = 40.8 psi < Fc⊥x' = 565.00 psi  (CSI = 0.07)   ➜  OK
3/12/2022 6
