Design Span (L): 19.75 ft.
Clear Span: 19.50 ft.
Total Span: 20.00 ft.
Selfweight: 237.5 lbs
Dist. Selfweight: 12.02 plf
Total Weight: 240.5 lbs
CL Beam Stability Factor 0.979 - - - - -
Beam Design 2022A121
3/12/2022 1
3/12/2022 2
Volumetotal = N[A x (L + lb)] = 3 x [16.88 x (237.00 + 3)] x (12 in./ft.)3 = 7.03 ft3
Volumespan = N[A x L] = 3 x [16.88 x 237.00] x (12 in./ft.)3 = 6.94 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 7.03 = 240.5 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 6.94 = 237.5 lbs
ws = 12.02 plf
19.75 ft.
19.50 ft.
1870.25 lbs
1870.25 lbs
3/12/2022 3
lu = Unbraced Length = 19.750 ft.
lu/d = = 21.07
le = 1.63lu + 3d = 1.63(237.0) + 3(11.25) = 420.06 in. = 35.00 ft.  (NDS Table 3.3.3)
Rb = = 15.28
 Rb = 15.28 < 50   ➜  OK
3/12/2022 4
FbE = = 2982.43 psi
CL =   = 0.979
Fbx' = (900)(1.00)(1)(1)(0.979)(1)(1)(1) = 881.5 psi
fb = = 1152.8 psi
 fb = 1152.8 psi > Fbx' = 881.5 psi  (CSI = 1.31)   ➜  NG
fv* = = 49.53 psi
 fv* = 49.53 psi < Fvx' = 180.00 psi  (CSI = 0.28)   ➜  OK
fv = = 54.72 psi
 fv = 54.72 psi < Fvx' = 180.00 psi  (CSI = 0.30)   ➜  OK
3/12/2022 5
ΔLL = = 0.40 in.
(L/d)LL = 237.00 / 0.40 = 591
 ΔLL = 0.40 in = L/591 < L/180   ➜  OK
ΔTL = = 0.75 in.
(L/d)TL = 237.00 / 0.75 = 316
 ΔTL = 0.75 in = L/316 < L/120   ➜  OK
fc⊥ = = 138.5 psi
 fc⊥ = 138.5 psi < Fc⊥x' = 625.00 psi  (CSI = 0.22)   ➜  OK
3/12/2022 6
