Beam Design - Roof Beam
Grade: SP DSS
Size: 4 x 8
Design Span (L): 10.63 ft.
Clear Span: 9.97 ft.
Total Span: 11.30 ft.
Bearing (lb): 8 in.
Live Load: 120 plf
Dead Load: 102 plf
Selfweight: 69.9 lbs
Dist. Selfweight: 6.58 plf
Total Weight: 74.3 lbs
Notes: 4 post / foot design with 4x4 uprights
CF Size Factor 1.1 1 - 1 - -
Beam Design 556 Stone Island 2022A120
3/12/2022 1
SP DSS 2200 1550 175 660 1850 1900000 690000 0.55
3/12/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [25.38 x (127.60 + 8)] x (12 in./ft.)3 = 1.99 ft3
Volumespan = N[A x L] = 1 x [25.38 x 127.60] x (12 in./ft.)3 = 1.87 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 1.99 = 74.3 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 1.87 = 69.9 lbs
Distributed Self Weight (ws) = = 6.58 plf
120 plf
102 plf
ws = 6.58 plf
10.63 ft.
9.97 ft.
11.30 ft.
1291.43 lbs
1291.43 lbs
3/12/2022 3
lu/d = = 3.31
Rb = = 5.41
 Rb = 5.41 < 50   ➜  OK
3/12/2022 4
FbE = = 28297.62 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (2200)(1.00)(1)(1)(1.1)(1)(1) = 2420.00 psi
CL =   = 0.995
Fbx' = (2200)(1.00)(1)(1)(0.995)(1.1)(1)(1) = 2408.8 psi
fb = = 1264.3 psi
 fb = 1264.3 psi < Fbx' = 2408.8 psi  (CSI = 0.52)   ➜  OK
fv* = = 63.67 psi
 fv* = 63.67 psi < Fvx' = 175.00 psi  (CSI = 0.36)   ➜  OK
fv = = 71.84 psi
 fv = 71.84 psi < Fvx' = 175.00 psi  (CSI = 0.41)   ➜  OK
3/12/2022 5
ΔLL = = 0.16 in.
(L/d)LL = 127.60 / 0.16 = 781
 ΔLL = 0.16 in = L/781 < L/240   ➜  OK
ΔTL = = 0.31 in.
(L/d)TL = 127.60 / 0.31 = 410
 ΔTL = 0.31 in = L/410 < L/180   ➜  OK
fc⊥ = = 46.1 psi
 fc⊥ = 46.1 psi < Fc⊥x' = 660.00 psi  (CSI = 0.07)   ➜  OK
3/12/2022 6
