Beam Design - Deck Beam
Grade: SP SS
Design Span (L): 10.63 ft.
Clear Span: 9.97 ft.
Total Span: 11.30 ft.
Bearing (lb): 8 in.
Live Load: 240 plf
Dead Load: 60 plf
Selfweight: 89.9 lbs
Dist. Selfweight: 8.46 plf
Total Weight: 95.6 lbs
Notes: 4 Post / footing design
Beam Design 556 Stone Island 2022A119
3/12/2022 1
SP SS 1950 1350 175 565 1700 1800000 660000 0.55
3/12/2022 2
Volumetotal = N[A x (L + lb)] = 3 x [10.88 x (127.60 + 8)] x (12 in./ft.)3 = 2.56 ft3
Volumespan = N[A x L] = 3 x [10.88 x 127.60] x (12 in./ft.)3 = 2.41 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 2.56 = 95.6 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 2.41 = 89.9 lbs
Distributed Self Weight (ws) = = 8.46 plf
240 plf
60 plf
ws = 8.46 plf
10.63 ft.
9.97 ft.
11.30 ft.
1742.73 lbs
1742.73 lbs
3/12/2022 3
lu/d = = 3.31
Rb = = 4.21
 Rb = 4.21 < 50   ➜  OK
3/12/2022 4
Eminy' = Eminy(CM)(Ct)(Ci) = 660000(1)(1)(1) = 660000 psi
FbE = = 44743.89 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (1950)(1.00)(1)(1)(1)(1)(1) = 1950.00 psi
CL =   = 0.998
Fbx' = (1950)(1.00)(1)(1)(0.998)(1)(1)(1) = 1945.6 psi
fb = = 1327.0 psi
 fb = 1327.0 psi < Fbx' = 1945.6 psi  (CSI = 0.68)   ➜  OK
fv* = = 66.83 psi
 fv* = 66.83 psi < Fvx' = 175.00 psi  (CSI = 0.38)   ➜  OK
fv = = 75.40 psi
 fv = 75.40 psi < Fvx' = 175.00 psi  (CSI = 0.43)   ➜  OK
3/12/2022 5
ΔLL = = 0.27 in.
(L/d)LL = 127.60 / 0.27 = 475
 ΔLL = 0.27 in = L/475 < L/360   ➜  OK
ΔTL = = 0.34 in.
(L/d)TL = 127.60 / 0.34 = 370
 ΔTL = 0.34 in = L/370 < L/240   ➜  OK
Ab = b x lb = 1.5 x 8 = 12.00 in2
fc⊥ = = 48.4 psi
 fc⊥ = 48.4 psi < Fc⊥x' = 565.00 psi  (CSI = 0.09)   ➜  OK
3/12/2022 6
