Design Span (L): 10.25 ft.
Clear Span: 10.00 ft.
Total Span: 10.50 ft.
Live Load: 40 plf
Dead Load: 0 plf
Selfweight: 20.1 lbs
Dist. Selfweight: 1.96 plf
Total Weight: 20.6 lbs
Beam Design 2022A117
3/11/2022 1
3/11/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [8.25 x (123.00 + 3)] x (12 in./ft.)3 = 0.60 ft3
Volumespan = N[A x L] = 1 x [8.25 x 123.00] x (12 in./ft.)3 = 0.59 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 0.60 = 20.6 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 0.59 = 20.1 lbs
40 plf
0 plf
ws = 1.96 plf
10.25 ft.
10.00 ft.
10.50 ft.
220.29 lbs
220.29 lbs
3/11/2022 3
fb = = 874.4 psi
 fb = 874.4 psi < Fbx' = 1170.0 psi  (CSI = 0.75)   ➜  OK
3/11/2022 4
fv* = = 35.60 psi
 fv* = 35.60 psi < Fvx' = 180.00 psi  (CSI = 0.20)   ➜  OK
fv = = 39.10 psi
 fv = 39.10 psi < Fvx' = 180.00 psi  (CSI = 0.22)   ➜  OK
3/11/2022 5
ΔLL = = 0.30 in.
(L/d)LL = 123.00 / 0.30 = 412
 ΔLL = 0.30 in = L/412 < L/360   ➜  OK
ΔTL = = 0.31 in.
(L/d)TL = 123.00 / 0.31 = 393
 ΔTL = 0.31 in = L/393 < L/240   ➜  OK
fc⊥ = = 49.0 psi
 fc⊥ = 49.0 psi < Fc⊥x' = 625.00 psi  (CSI = 0.08)   ➜  OK
3/11/2022 6
