Beam Design - Structural Flint
Selfweight: 126.8 lbs
Dist. Selfweight: 10.79 plf
Total Weight: 129.5 lbs
Beam Design 17 Estelle Street 2022036N
3/11/2022 1
3/11/2022 2
Volumetotal = N[A x (L + lb)] = 3 x [13.88 x (141.00 + 3)] x (12 in./ft.)3 = 3.47 ft3
Volumespan = N[A x L] = 3 x [13.88 x 141.00] x (12 in./ft.)3 = 3.40 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 3.47 = 129.5 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 3.40 = 126.8 lbs
Distributed Self Weight (ws) = = 10.79 plf
ws = 10.79 plf
1114.74 lbs
1114.74 lbs
3/11/2022 3
fb = = 599.6 psi
 fb = 599.6 psi < Fbx' = 920.0 psi  (CSI = 0.65)   ➜  OK
3/11/2022 4
fv* = = 34.17 psi
 fv* = 34.17 psi < Fvx' = 201.25 psi  (CSI = 0.17)   ➜  OK
fv = = 39.33 psi
 fv = 39.33 psi < Fvx' = 201.25 psi  (CSI = 0.20)   ➜  OK
3/11/2022 5
ΔLL = = 0.10 in.
(L/d)LL = 141.00 / 0.10 = 1366
 ΔLL = 0.10 in = L/1366 < L/360   ➜  OK
ΔTL = = 0.19 in.
(L/d)TL = 141.00 / 0.19 = 735
 ΔTL = 0.19 in = L/735 < L/240   ➜  OK
fc⊥ = = 82.6 psi
 fc⊥ = 82.6 psi < Fc⊥x' = 565.00 psi  (CSI = 0.15)   ➜  OK
3/11/2022 6
