Beam Design - Roof
Grade: SPF SS
Live Load: 115.6100 plf
Dead Load: 15 plf
Selfweight: 19.6 lbs
Dist. Selfweight: 1.67 plf
Total Weight: 20.0 lbs
Beam Design d f Keene Keene
2/26/2022 1
2/26/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [8.25 x (141.00 + 3)] x (12 in./ft.)3 = 0.69 ft3
Volumespan = N[A x L] = 1 x [8.25 x 141.00] x (12 in./ft.)3 = 0.67 ft3
Total Weight (WT) = ρw x Volumetotal = 29.10 x 0.69 = 20.0 lbs
Self Weight (WS) = ρw x Volumespan = 29.10 x 0.67 = 19.6 lbs
115.6100 plf
15 plf
ws = 1.67 plf
793.66 lbs
793.66 lbs
2/26/2022 3
Fbx' = (1250)(1.15)(1)(1)(1)(1.3)(1)(1) = 1868.8 psi
fb = = 3622.3 psi
 fb = 3622.3 psi > Fbx' = 1868.8 psi  (CSI = 1.94)   ➜  NG
2/26/2022 4
fv* = = 130.27 psi
 fv* = 130.27 psi < Fvx' = 155.25 psi  (CSI = 0.84)   ➜  OK
fv = = 141.30 psi
 fv = 141.30 psi < Fvx' = 155.25 psi  (CSI = 0.91)   ➜  OK
2/26/2022 5
ΔLL = = 1.59 in.
(L/d)LL = 141.00 / 1.59 = 89
 ΔLL = 1.59 in = L/89 > L/360   ➜  NG
ΔTL = = 1.82 in.
(L/d)TL = 141.00 / 1.82 = 78
 ΔTL = 1.82 in = L/78 > L/240   ➜  NG
fc⊥ = = 176.4 psi
 fc⊥ = 176.4 psi < Fc⊥x' = 425.00 psi  (CSI = 0.41)   ➜  OK
2/26/2022 6
