Design Span (L): 14.25 ft.
Clear Span: 14.00 ft.
Total Span: 14.50 ft.
Live Load: 120 plf
Dead Load: 30 plf
Selfweight: 47.0 lbs
Dist. Selfweight: 3.30 plf
Total Weight: 47.8 lbs
Beam Design 2022A100
2/24/2022 1
2/24/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [13.88 x (171.00 + 3)] x (12 in./ft.)3 = 1.40 ft3
Volumespan = N[A x L] = 1 x [13.88 x 171.00] x (12 in./ft.)3 = 1.37 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 1.40 = 47.8 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 1.37 = 47.0 lbs
120 plf
30 plf
ws = 3.30 plf
14.25 ft.
14.50 ft.
1111.39 lbs
1111.39 lbs
2/24/2022 3
fb = = 2182.9 psi
 fb = 2182.9 psi > Fbx' = 990.0 psi  (CSI = 2.20)   ➜  NG
2/24/2022 4
fv* = = 105.30 psi
 fv* = 105.30 psi < Fvx' = 180.00 psi  (CSI = 0.59)   ➜  OK
fv = = 118.08 psi
 fv = 118.08 psi < Fvx' = 180.00 psi  (CSI = 0.66)   ➜  OK
2/24/2022 5
ΔLL = = 0.70 in.
(L/d)LL = 171.00 / 0.70 = 243
 ΔLL = 0.70 in = L/243 > L/360   ➜  NG
ΔTL = = 0.90 in.
(L/d)TL = 171.00 / 0.90 = 190
 ΔTL = 0.90 in = L/190 > L/240   ➜  NG
fc⊥ = = 247.0 psi
 fc⊥ = 247.0 psi < Fc⊥x' = 625.00 psi  (CSI = 0.40)   ➜  OK
2/24/2022 6
