Grade: DF SS
Design Span (L): 8.00 ft.
Clear Span: 7.50 ft.
Total Span: 8.50 ft.
Live Load: 160 plf
Dead Load: 40 plf
Selfweight: 31.4 lbs
Dist. Selfweight: 3.92 plf
Total Weight: 33.3 lbs
Beam Design 2022A1
1/2/2022 1
Beam Design 2022A1
1/2/2022 2
Volumetotal = N[A x (L + lb)] = 2 x [8.25 x (96.00 + 6)] x (12 in./ft.)3 = 0.97 ft3
Volumespan = N[A x L] = 2 x [8.25 x 96.00] x (12 in./ft.)3 = 0.92 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 0.97 = 33.3 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 0.92 = 31.4 lbs
160 plf
40 plf
ws = 3.92 plf
7.50 ft.
8.50 ft.
866.66 lbs
866.66 lbs
Beam Design 2022A1
1/2/2022 3
Fbx' = (1500)(1.00)(1)(1)(1)(1.3)(1)(1) = 1950.0 psi
fb = = 1294.3 psi
 fb = 1294.3 psi < Fbx' = 1950.0 psi  (CSI = 0.66)   ➜  OK
Beam Design 2022A1
1/2/2022 4
fv* = = 65.66 psi
 fv* = 65.66 psi < Fvx' = 180.00 psi  (CSI = 0.36)   ➜  OK
fv = = 74.15 psi
 fv = 74.15 psi < Fvx' = 180.00 psi  (CSI = 0.41)   ➜  OK
Beam Design 2022A1
1/2/2022 5
ΔLL = = 0.19 in.
(L/d)LL = 96.00 / 0.19 = 515
 ΔLL = 0.19 in = L/515 < L/360   ➜  OK
ΔTL = = 0.24 in.
(L/d)TL = 96.00 / 0.24 = 404
 ΔTL = 0.24 in = L/404 < L/240   ➜  OK
fc⊥ = = 48.1 psi
 fc⊥ = 48.1 psi < Fc⊥x' = 625.00 psi  (CSI = 0.08)   ➜  OK
Beam Design 2022A1
1/2/2022 6
