Size: 4 x 6
Design Span (L): 5.25 ft.
Clear Span: 5.00 ft.
Total Span: 5.50 ft.
Live Load: 132 plf
Dead Load: 26 plf
Selfweight: 27.1 lbs
Dist. Selfweight: 5.16 plf
Total Weight: 28.4 lbs
Beam Design 2021A97
1/26/2021 1
Beam Design 2021A97
1/26/2021 2
= 38.58 lbs/ft3
Volumetotal = N[A x (L + lb)] = 1 x [19.25 x (63.00 + 3)] x (12 in./ft.)3 = 0.74 ft3
Volumespan = N[A x L] = 1 x [19.25 x 63.00] x (12 in./ft.)3 = 0.70 ft3
Total Weight (WT) = ρw x Volumetotal = 38.58 x 0.74 = 28.4 lbs
Self Weight (WS) = ρw x Volumespan = 38.58 x 0.70 = 27.1 lbs
Distributed Self Weight (ws) = = 5.16 plf
132 plf
26 plf
ws = 5.16 plf
5.25 ft.
5.00 ft.
5.50 ft.
448.68 lbs
448.68 lbs
Beam Design 2021A97
1/26/2021 3
fb = = 382.3 psi
 fb = 382.3 psi < Fbx' = 1000.0 psi  (CSI = 0.38)   ➜  OK
Beam Design 2021A97
1/26/2021 4
fv* = = 27.55 psi
 fv* = 27.55 psi < Fvx' = 169.75 psi  (CSI = 0.16)   ➜  OK
fv = = 33.37 psi
 fv = 33.37 psi < Fvx' = 169.75 psi  (CSI = 0.20)   ➜  OK
Beam Design 2021A97
1/26/2021 5
ΔLL = = 0.04 in.
(L/d)LL = 63.00 / 0.04 = 1707
 ΔLL = 0.04 in = L/1707 < L/360   ➜  OK
ΔTL = = 0.05 in.
(L/d)TL = 63.00 / 0.05 = 1381
 ΔTL = 0.05 in = L/1381 < L/240   ➜  OK
fc⊥ = = 42.7 psi
 fc⊥ = 42.7 psi < Fc⊥x' = 378.55 psi  (CSI = 0.11)   ➜  OK
Beam Design 2021A97
1/26/2021 6
