Design Span (L): 15.66 ft.
Clear Span: 15.33 ft.
Total Span: 15.99 ft.
Bearing (lb): 4 in.
Live Load: 136 plf
Dead Load: 76 plf
Selfweight: 188.3 lbs
Dist. Selfweight: 12.02 plf
Total Weight: 192.3 lbs
CL Beam Stability Factor 0.981 - - - - -
Beam Design 2021A94
1/25/2021 1
Beam Design 2021A94
1/25/2021 2
Volumetotal = N[A x (L + lb)] = 3 x [16.88 x (187.92 + 4)] x (12 in./ft.)3 = 5.62 ft3
Volumespan = N[A x L] = 3 x [16.88 x 187.92] x (12 in./ft.)3 = 5.51 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 5.62 = 192.3 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 5.51 = 188.3 lbs
136 plf
76 plf
ws = 12.02 plf
15.66 ft.
15.33 ft.
15.99 ft.
1791.45 lbs
1791.45 lbs
Beam Design 2021A94
1/25/2021 3
lu = Unbraced Length = 15.66 ft.
lu/d = = 16.70
le = 1.63lu + 3d = 1.63(187.9) + 3(11.25) = 340.06 in. = 28.34 ft.  (NDS Table 3.3.3)
Rb = = 13.74
 Rb = 13.74 < 50   ➜  OK
Beam Design 2021A94
1/25/2021 4
FbE = = 3684.06 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (900)(1.15)(1)(1)(1)(1)(1) = 1035.00 psi
CL =   = 0.981
Fbx' = (900)(1.15)(1)(1)(0.981)(1)(1)(1) = 1015.7 psi
fb = = 868.2 psi
 fb = 868.2 psi < Fbx' = 1015.7 psi  (CSI = 0.85)   ➜  OK
fv* = = 45.75 psi
 fv* = 45.75 psi < Fvx' = 207.00 psi  (CSI = 0.22)   ➜  OK
fv = = 51.97 psi
 fv = 51.97 psi < Fvx' = 207.00 psi  (CSI = 0.25)   ➜  OK
Beam Design 2021A94
1/25/2021 5
ΔLL = = 0.22 in.
(L/d)LL = 187.92 / 0.22 = 872
 ΔLL = 0.22 in = L/872 < L/180   ➜  OK
ΔTL = = 0.35 in.
(L/d)TL = 187.92 / 0.35 = 530
 ΔTL = 0.35 in = L/530 < L/120   ➜  OK
fc⊥ = = 99.5 psi
 fc⊥ = 99.5 psi < Fc⊥x' = 625.00 psi  (CSI = 0.16)   ➜  OK
Beam Design 2021A94
1/25/2021 6
