Beam Design - x
Size: 6.75 x 10.5
Design Span (L): 13.50 ft.
Clear Span: 13.00 ft.
Total Span: 14.00 ft.
Live Load: 678 plf
Dead Load: 0 plf
Selfweight: 224.3 lbs
Dist. Selfweight: 16.62 plf
Total Weight: 232.6 lbs
Notes: x
Beam Design x x x x
1/17/2021 1
b = 6.750 in.
d = 10.500 in.
A = 6.750 x 10.500 = 70.88 in.2
Sx = (6.750)(10.500)2/6 = 124.03 in.3
Sy = (6.750)2(10.500)/6 = 79.73 in.3
Ix = (6.750)(10.500)3/12 = 651.16 in.4
Iy = (6.750)3(10.500)/12 = 269.10 in.4
Beam Design x x x x
1/17/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [70.88 x (162.00 + 6)] x (12 in./ft.)3 = 6.89 ft3
Volumespan = N[A x L] = 1 x [70.88 x 162.00] x (12 in./ft.)3 = 6.64 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 6.89 = 232.6 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 6.64 = 224.3 lbs
Distributed Self Weight (ws) = = 16.62 plf
678 plf
0 plf
  ws = 16.62 plf
13.50 ft.
13.00 ft.
4862.32 lbs
4862.32 lbs
Beam Design x x x x
1/17/2021 3
fb = = 1531.0 psi
 fb = 1531.0 psi < Fbx' = 2760.0 psi  (CSI = 0.55)   ➜  OK
Beam Design x x x x
1/17/2021 4
fv* = = 86.37 psi
 fv* = 86.37 psi < Fvx' = 304.75 psi  (CSI = 0.28)   ➜  OK
fv = = 99.23 psi
 fv = 99.23 psi < Fvx' = 304.75 psi  (CSI = 0.33)   ➜  OK
Beam Design x x x x
1/17/2021 5
ΔLL = = 0.43 in.
(L/d)LL = 162.00 / 0.43 = 375
 ΔLL = 0.43 in = L/375 < L/360   ➜  OK
ΔTL = = 0.44 in.
(L/d)TL = 162.00 / 0.44 = 366
 ΔTL = 0.44 in = L/366 < L/240   ➜  OK
fc⊥ = = 120.1 psi
 fc⊥ = 120.1 psi < Fc⊥x' = 650.00 psi  (CSI = 0.18)   ➜  OK
Beam Design x x x x
1/17/2021 6
