Beam Design - x
Size: 6.75 x 12
Design Span (L): 15.00 ft.
Clear Span: 14.75 ft.
Total Span: 15.25 ft.
Live Load: 735 plf
Dead Load: 0 plf
Selfweight: 284.9 lbs
Dist. Selfweight: 18.99 plf
Total Weight: 289.6 lbs
Notes: x
Beam Design x x x x
1/17/2021 1
b = 6.750 in.
A = 6.750 x 12.000 = 81.00 in.2
Sx = (6.750)(12.000)2/6 = 162.00 in.3
Sy = (6.750)2(12.000)/6 = 91.13 in.3
Ix = (6.750)(12.000)3/12 = 972.00 in.4
Iy = (6.750)3(12.000)/12 = 307.55 in.4
Beam Design x x x x
1/17/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [81.00 x (180.00 + 3)] x (12 in./ft.)3 = 8.58 ft3
Volumespan = N[A x L] = 1 x [81.00 x 180.00] x (12 in./ft.)3 = 8.44 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 8.58 = 289.6 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 8.44 = 284.9 lbs
Distributed Self Weight (ws) = = 18.99 plf
735 plf
0 plf
  ws = 18.99 plf
15.00 ft.
14.75 ft.
15.25 ft.
5749.18 lbs
5749.18 lbs
Beam Design x x x x
1/17/2021 3
fb = = 1570.8 psi
 fb = 1570.8 psi < Fbx' = 2760.0 psi  (CSI = 0.57)   ➜  OK
Beam Design x x x x
1/17/2021 4
fv* = = 90.76 psi
 fv* = 90.76 psi < Fvx' = 304.75 psi  (CSI = 0.30)   ➜  OK
fv = = 104.72 psi
 fv = 104.72 psi < Fvx' = 304.75 psi  (CSI = 0.34)   ➜  OK
Beam Design x x x x
1/17/2021 5
ΔLL = = 0.48 in.
(L/d)LL = 180.00 / 0.48 = 376
 ΔLL = 0.48 in = L/376 < L/360   ➜  OK
ΔTL = = 0.49 in.
(L/d)TL = 180.00 / 0.49 = 367
 ΔTL = 0.49 in = L/367 < L/240   ➜  OK
fc⊥ = = 283.9 psi
 fc⊥ = 283.9 psi < Fc⊥x' = 650.00 psi  (CSI = 0.44)   ➜  OK
Beam Design x x x x
1/17/2021 6
