Beam Design - x
Size: 6.75 x 16.5
Design Span (L): 15.00 ft.
Clear Span: 14.50 ft.
Total Span: 15.50 ft.
Live Load: 1470 plf
Dead Load: 0 plf
Selfweight: 391.7 lbs
Dist. Selfweight: 26.11 plf
Total Weight: 404.7 lbs
Notes: x
CV Volume Factor 0.975b - - - - -
Beam Design x x x x
1/17/2021 1
b = 6.750 in.
d = 16.500 in.
A = 6.750 x 16.500 = 111.38 in.2
Sx = (6.750)(16.500)2/6 = 306.28 in.3
Sy = (6.750)2(16.500)/6 = 125.30 in.3
Ix = (6.750)(16.500)3/12 = 2526.82 in.4
Iy = (6.750)3(16.500)/12 = 422.88 in.4
Beam Design x x x x
1/17/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [111.38 x (180.00 + 6)] x (12 in./ft.)3 = 11.99 ft3
Volumespan = N[A x L] = 1 x [111.38 x 180.00] x (12 in./ft.)3 = 11.60 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 11.99 = 404.7 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 11.60 = 391.7 lbs
Distributed Self Weight (ws) = = 26.11 plf
1470 plf
0 plf
  ws = 26.11 plf
15.00 ft.
14.50 ft.
15.50 ft.
11594.87 lbs
11594.87 lbs
Beam Design x x x x
1/17/2021 3
CV = = 0.975
CV = 0.975 < CL = 1
Fbx' = (2400)(1.15)(1)(1)(0.975) = 2689.9 psi
fb = = 1648.6 psi
 fb = 1648.6 psi < Fbx' = 2689.9 psi  (CSI = 0.61)   ➜  OK
Beam Design x x x x
1/17/2021 4
fv* = = 123.42 psi
 fv* = 123.42 psi < Fvx' = 304.75 psi  (CSI = 0.40)   ➜  OK
fv = = 151.12 psi
 fv = 151.12 psi < Fvx' = 304.75 psi  (CSI = 0.50)   ➜  OK
Beam Design x x x x
1/17/2021 5
ΔLL = = 0.37 in.
(L/d)LL = 180.00 / 0.37 = 489
 ΔLL = 0.37 in = L/489 < L/360   ➜  OK
ΔTL = = 0.37 in.
(L/d)TL = 180.00 / 0.37 = 480
 ΔTL = 0.37 in = L/480 < L/240   ➜  OK
fc⊥ = = 286.3 psi
 fc⊥ = 286.3 psi < Fc⊥x' = 650.00 psi  (CSI = 0.44)   ➜  OK
Beam Design x x x x
1/17/2021 6
