Beam Design - Douglas Residnece
Grade: DF No.1
Design Span (L): 14.25 ft.
Clear Span: 14.00 ft.
Total Span: 14.50 ft.
Quantity (N): 4
Live Load: 274 plf
Dead Load: 137 plf
Selfweight: 228.5 lbs
Dist. Selfweight: 16.03 plf
Total Weight: 232.5 lbs
Beam Design Raymond Douglas 276 Tryon Street, Middletown, CT 12413
12/29/2021 1
12/29/2021 2
Volumetotal = N[A x (L + lb)] = 4 x [16.88 x (171.00 + 3)] x (12 in./ft.)3 = 6.80 ft3
Volumespan = N[A x L] = 4 x [16.88 x 171.00] x (12 in./ft.)3 = 6.68 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 6.80 = 232.5 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 6.68 = 228.5 lbs
274 plf
137 plf
ws = 16.03 plf
14.25 ft.
14.50 ft.
3095.99 lbs
3095.99 lbs
12/29/2021 3
fb = = 1027.7 psi
 fb = 1027.7 psi > Fbx' = 1000.0 psi  (CSI = 1.03)   ➜  NG
12/29/2021 4
fv* = = 58.72 psi
 fv* = 58.72 psi < Fvx' = 180.00 psi  (CSI = 0.33)   ➜  OK
fv = = 67.61 psi
 fv = 67.61 psi < Fvx' = 180.00 psi  (CSI = 0.38)   ➜  OK
12/29/2021 5
ΔLL = = 0.21 in.
(L/d)LL = 171.00 / 0.21 = 814
 ΔLL = 0.21 in = L/814 < L/360   ➜  OK
ΔTL = = 0.33 in.
(L/d)TL = 171.00 / 0.33 = 522
 ΔTL = 0.33 in = L/522 < L/240   ➜  OK
fc⊥ = = 172.0 psi
 fc⊥ = 172.0 psi < Fc⊥x' = 625.00 psi  (CSI = 0.28)   ➜  OK
12/29/2021 6
