Beam Design - Douglas Residnece
Size: 3.5 x 7.5
Design Span (L): 14.25 ft.
Clear Span: 14.00 ft.
Total Span: 14.50 ft.
Live Load: 274 plf
Dead Load: 137 plf
Selfweight: 263.1 lbs
Dist. Selfweight: 18.46 plf
Total Weight: 267.7 lbs
Beam Design Raymond Douglas 276 Tryon Street, Middletown, CT 12413
12/29/2021 1
d = 7.500 in.
A = 3.500 x 7.500 = 26.25 in.2
Sx = (3.500)(7.500)2/6 = 32.81 in.3
Sy = (3.500)2(7.500)/6 = 15.31 in.3
Ix = (3.500)(7.500)3/12 = 123.05 in.4
Iy = (3.500)3(7.500)/12 = 26.80 in.4
12/29/2021 2
Volumetotal = N[A x (L + lb)] = 3 x [26.25 x (171.00 + 3)] x (12 in./ft.)3 = 7.93 ft3
Volumespan = N[A x L] = 3 x [26.25 x 171.00] x (12 in./ft.)3 = 7.79 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 7.93 = 267.7 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 7.79 = 263.1 lbs
Distributed Self Weight (ws) = = 18.46 plf
274 plf
137 plf
  ws = 18.46 plf
14.25 ft.
14.50 ft.
3113.61 lbs
3113.61 lbs
12/29/2021 3
fb = = 1328.9 psi
 fb = 1328.9 psi < Fbx' = 2400.0 psi  (CSI = 0.55)   ➜  OK
12/29/2021 4
fv* = = 53.17 psi
 fv* = 53.17 psi < Fvx' = 265.00 psi  (CSI = 0.20)   ➜  OK
fv = = 58.28 psi
 fv = 58.28 psi < Fvx' = 265.00 psi  (CSI = 0.22)   ➜  OK
12/29/2021 5
ΔLL = = 0.38 in.
(L/d)LL = 171.00 / 0.38 = 447
 ΔLL = 0.38 in = L/447 < L/360   ➜  OK
ΔTL = = 0.60 in.
(L/d)TL = 171.00 / 0.60 = 285
 ΔTL = 0.60 in = L/285 < L/240   ➜  OK
fc⊥ = = 98.8 psi
 fc⊥ = 98.8 psi < Fc⊥x' = 650.00 psi  (CSI = 0.15)   ➜  OK
12/29/2021 6
