Beam Design - Douglas Residnece
Size: 3.5 x 7.5
Design Span (L): 14.25 ft.
Clear Span: 14.00 ft.
Total Span: 14.50 ft.
Live Load: 411 plf
Dead Load: 137 plf
Selfweight: 263.1 lbs
Dist. Selfweight: 18.46 plf
Total Weight: 267.7 lbs
Beam Design Anthony Torello 276 Tryon Street, Middletown, CT 12413
12/29/2021 1
d = 7.500 in.
A = 3.500 x 7.500 = 26.25 in.2
Sx = (3.500)(7.500)2/6 = 32.81 in.3
Sy = (3.500)2(7.500)/6 = 15.31 in.3
Ix = (3.500)(7.500)3/12 = 123.05 in.4
Iy = (3.500)3(7.500)/12 = 26.80 in.4
12/29/2021 2
Volumetotal = N[A x (L + lb)] = 3 x [26.25 x (171.00 + 3)] x (12 in./ft.)3 = 7.93 ft3
Volumespan = N[A x L] = 3 x [26.25 x 171.00] x (12 in./ft.)3 = 7.79 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 7.93 = 267.7 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 7.79 = 263.1 lbs
Distributed Self Weight (ws) = = 18.46 plf
411 plf
137 plf
  ws = 18.46 plf
14.25 ft.
14.50 ft.
4106.86 lbs
4106.86 lbs
12/29/2021 3
fb = = 1752.8 psi
 fb = 1752.8 psi < Fbx' = 2400.0 psi  (CSI = 0.73)   ➜  OK
12/29/2021 4
fv* = = 70.13 psi
 fv* = 70.13 psi < Fvx' = 265.00 psi  (CSI = 0.26)   ➜  OK
fv = = 76.88 psi
 fv = 76.88 psi < Fvx' = 265.00 psi  (CSI = 0.29)   ➜  OK
12/29/2021 5
ΔLL = = 0.57 in.
(L/d)LL = 171.00 / 0.57 = 298
 ΔLL = 0.57 in = L/298 > L/360   ➜  NG
ΔTL = = 0.79 in.
(L/d)TL = 171.00 / 0.79 = 216
 ΔTL = 0.79 in = L/216 > L/240   ➜  NG
fc⊥ = = 130.4 psi
 fc⊥ = 130.4 psi < Fc⊥x' = 650.00 psi  (CSI = 0.20)   ➜  OK
12/29/2021 6
