Beam Design - Douglas Residnece
Design Span (L): 14.25 ft.
Clear Span: 14.00 ft.
Total Span: 14.50 ft.
Live Load: 411 plf
Dead Load: 137 plf
Selfweight: 171.4 lbs
Dist. Selfweight: 12.02 plf
Total Weight: 174.4 lbs
Beam Design 276 Tryon Street, Middletown, CT 2021A783
12/29/2021 1
12/29/2021 2
Volumetotal = N[A x (L + lb)] = 3 x [16.88 x (171.00 + 3)] x (12 in./ft.)3 = 5.10 ft3
Volumespan = N[A x L] = 3 x [16.88 x 171.00] x (12 in./ft.)3 = 5.01 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 5.10 = 174.4 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 5.01 = 171.4 lbs
411 plf
137 plf
ws = 12.02 plf
14.25 ft.
14.50 ft.
4060.18 lbs
4060.18 lbs
12/29/2021 3
fb = = 1797.1 psi
 fb = 1797.1 psi > Fbx' = 900.0 psi  (CSI = 2.00)   ➜  NG
12/29/2021 4
fv* = = 102.67 psi
 fv* = 102.67 psi < Fvx' = 180.00 psi  (CSI = 0.57)   ➜  OK
fv = = 118.23 psi
 fv = 118.23 psi < Fvx' = 180.00 psi  (CSI = 0.66)   ➜  OK
12/29/2021 5
ΔLL = = 0.45 in.
(L/d)LL = 171.00 / 0.45 = 383
 ΔLL = 0.45 in = L/383 < L/360   ➜  OK
ΔTL = = 0.61 in.
(L/d)TL = 171.00 / 0.61 = 281
 ΔTL = 0.61 in = L/281 < L/240   ➜  OK
fc⊥ = = 300.8 psi
 fc⊥ = 300.8 psi < Fc⊥x' = 625.00 psi  (CSI = 0.48)   ➜  OK
12/29/2021 6
