Beam Design - x
Size: 6.75 x 10.5
Design Span (L): 10.25 ft.
Clear Span: 10.00 ft.
Total Span: 10.50 ft.
Live Load: 1278 plf
Dead Load: 0 plf
Selfweight: 170.3 lbs
Dist. Selfweight: 16.62 plf
Total Weight: 174.5 lbs
Notes: x
Beam Design x x x x
1/17/2021 1
b = 6.750 in.
d = 10.500 in.
A = 6.750 x 10.500 = 70.88 in.2
Sx = (6.750)(10.500)2/6 = 124.03 in.3
Sy = (6.750)2(10.500)/6 = 79.73 in.3
Ix = (6.750)(10.500)3/12 = 651.16 in.4
Iy = (6.750)3(10.500)/12 = 269.10 in.4
Beam Design x x x x
1/17/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [70.88 x (123.00 + 3)] x (12 in./ft.)3 = 5.17 ft3
Volumespan = N[A x L] = 1 x [70.88 x 123.00] x (12 in./ft.)3 = 5.04 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 5.17 = 174.5 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 5.04 = 170.3 lbs
Distributed Self Weight (ws) = = 16.62 plf
1278 plf
0 plf
  ws = 16.62 plf
10.25 ft.
10.00 ft.
10.50 ft.
6796.74 lbs
6796.74 lbs
Beam Design x x x x
1/17/2021 3
fb = = 1644.9 psi
 fb = 1644.9 psi < Fbx' = 2760.0 psi  (CSI = 0.60)   ➜  OK
Beam Design x x x x
1/17/2021 4
fv* = = 116.45 psi
 fv* = 116.45 psi < Fvx' = 304.75 psi  (CSI = 0.38)   ➜  OK
fv = = 140.42 psi
 fv = 140.42 psi < Fvx' = 304.75 psi  (CSI = 0.46)   ➜  OK
Beam Design x x x x
1/17/2021 5
ΔLL = = 0.27 in.
(L/d)LL = 123.00 / 0.27 = 454
 ΔLL = 0.27 in = L/454 < L/360   ➜  OK
ΔTL = = 0.27 in.
(L/d)TL = 123.00 / 0.27 = 448
 ΔTL = 0.27 in = L/448 < L/240   ➜  OK
fc⊥ = = 335.6 psi
 fc⊥ = 335.6 psi < Fc⊥x' = 650.00 psi  (CSI = 0.52)   ➜  OK
Beam Design x x x x
1/17/2021 6
