Size: 4 x 16
Design Span (L): 12.25 ft.
Clear Span: 12.00 ft.
Total Span: 12.50 ft.
Selfweight: 152.8 lbs
Dist. Selfweight: 12.47 plf
Total Weight: 155.9 lbs
Beam Design 2021A773
12/24/2021 1
d = 15.000 in.
12/24/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [52.50 x (147.00 + 3)] x (12 in./ft.)3 = 4.56 ft3
Volumespan = N[A x L] = 1 x [52.50 x 147.00] x (12 in./ft.)3 = 4.47 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 4.56 = 155.9 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 4.47 = 152.8 lbs
ws = 12.47 plf
12.25 ft.
12.50 ft.
1171.69 lbs
1171.69 lbs
12/24/2021 3
lu/d = = 1.60
Rb = = 7.78
 Rb = 7.78 < 50   ➜  OK
12/24/2021 4
Eminy' = Eminy(CM)(Ct)(Ci) = 580000(1)(0.9)(1) = 522000 psi
FbE = = 10347.09 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (900)(1.00)(1)(0.8)(1)(1)(1) = 720.00 psi
CL =   = 0.996
Fbx' = (900)(1.00)(1)(0.8)(0.996)(1)(1)(1) = 717.3 psi
fb = = 321.5 psi
 fb = 321.5 psi < Fbx' = 717.3 psi  (CSI = 0.45)   ➜  OK
Fvx' = (180)(1.00)(1)(0.8)(1) = 144.00 psi
fv* = = 26.11 psi
 fv* = 26.11 psi < Fvx' = 144.00 psi  (CSI = 0.18)   ➜  OK
fv = = 32.81 psi
 fv = 32.81 psi < Fvx' = 144.00 psi  (CSI = 0.23)   ➜  OK
12/24/2021 5
Ex' = Ex(CM)(Ct)(Ci) = 1600000(1)(0.9)(1) = 1440000 psi
ΔLL = = 0.04 in.
(L/d)LL = 147.00 / 0.04 = 4113
 ΔLL = 0.04 in = L/4113 < L/360   ➜  OK
ΔTL = = 0.07 in.
(L/d)TL = 147.00 / 0.07 = 2194
 ΔTL = 0.07 in = L/2194 < L/240   ➜  OK
fc⊥ = = 111.6 psi
 fc⊥ = 111.6 psi < Fc⊥x' = 500.00 psi  (CSI = 0.22)   ➜  OK
12/24/2021 6
