Size: 3.125 x 12
Design Span (L): 19.17 ft.
Clear Span: 18.83 ft.
Total Span: 19.50 ft.
Bearing (lb): 4 in.
Live Load: plf
Dead Load: 949 plf
Selfweight: 168.5 lbs
Dist. Selfweight: 8.79 plf
Total Weight: 171.4 lbs
Beam Design 2021A770
12/21/2021 1
b = 3.125 in.
12/21/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [37.50 x (230.00 + 4)] x (12 in./ft.)3 = 5.08 ft3
Volumespan = N[A x L] = 1 x [37.50 x 230.00] x (12 in./ft.)3 = 4.99 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 5.08 = 171.4 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 4.99 = 168.5 lbs
plf
949 plf
  ws = 8.79 plf
19.17 ft.
18.83 ft.
19.50 ft.
9338.63 lbs
9338.63 lbs
12/21/2021 3
fb = = 7037.4 psi
 fb = 7037.4 psi > Fbx' = 2400.0 psi  (CSI = 2.93)   ➜  NG
12/21/2021 4
fv* = = 328.85 psi
 fv* = 328.85 psi > Fvx' = 265.00 psi  (CSI = 1.24)   ➜  NG
fv = = 367.16 psi
 fv = 367.16 psi > Fvx' = 265.00 psi  (CSI = 1.39)   ➜  NG
12/21/2021 5
ΔLL = = 0.00 in.
(L/d)LL = 230.00 / 0.00 = ∞
ΔTL = = 3.59 in.
(L/d)TL = 230.00 / 3.59 = 64
 ΔTL = 3.59 in = L/64 > L/120   ➜  NG
Ab = b x lb = 3.125 x 4 = 12.50 in2
fc⊥ = = 747.1 psi
 fc⊥ = 747.1 psi > Fc⊥x' = 650.00 psi  (CSI = 1.15)   ➜  NG
12/21/2021 6
