Beam Design - GWE L9
Grade: DF No.1 & Btr
Live Load: 180 plf
Dead Load: 15 plf
Selfweight: 47.1 lbs
Dist. Selfweight: 4.01 plf
Total Weight: 48.1 lbs
Notes: x
Beam Design Brian Holmes PO Box 276 GWE L9
1/17/2021 1
1/17/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [16.88 x (141.00 + 3)] x (12 in./ft.)3 = 1.41 ft3
Volumespan = N[A x L] = 1 x [16.88 x 141.00] x (12 in./ft.)3 = 1.38 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 1.41 = 48.1 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 1.38 = 47.1 lbs
180 plf
15 plf
ws = 4.01 plf
1194.05 lbs
1194.05 lbs
1/17/2021 3
Fbx' = (1200)(1.15)(1)(1)(1)(1)(1)(1) = 1380.0 psi
fb = = 1302.5 psi
 fb = 1302.5 psi < Fbx' = 1380.0 psi  (CSI = 0.94)   ➜  OK
1/17/2021 4
fv* = = 87.34 psi
 fv* = 87.34 psi < Fvx' = 207.00 psi  (CSI = 0.42)   ➜  OK
fv = = 103.93 psi
 fv = 103.93 psi < Fvx' = 207.00 psi  (CSI = 0.50)   ➜  OK
1/17/2021 5
ΔLL = = 0.24 in.
(L/d)LL = 141.00 / 0.24 = 585
 ΔLL = 0.24 in = L/585 < L/360   ➜  OK
ΔTL = = 0.27 in.
(L/d)TL = 141.00 / 0.27 = 529
 ΔTL = 0.27 in = L/529 < L/240   ➜  OK
fc⊥ = = 265.3 psi
 fc⊥ = 265.3 psi < Fc⊥x' = 625.00 psi  (CSI = 0.42)   ➜  OK
1/17/2021 6
