Size: 3.125 x 12
Design Span (L): 11.67 ft.
Clear Span: 11.33 ft.
Bearing (lb): 4 in.
Live Load: plf
Dead Load: 949 plf
Selfweight: 102.6 lbs
Dist. Selfweight: 8.79 plf
Total Weight: 105.5 lbs
Beam Design 2021A769
12/21/2021 1
b = 3.125 in.
12/21/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [37.50 x (140.00 + 4)] x (12 in./ft.)3 = 3.13 ft3
Volumespan = N[A x L] = 1 x [37.50 x 140.00] x (12 in./ft.)3 = 3.04 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 3.13 = 105.5 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 3.04 = 102.6 lbs
plf
949 plf
  ws = 8.79 plf
11.67 ft.
11.33 ft.
5746.91 lbs
5746.91 lbs
12/21/2021 3
fb = = 2607.5 psi
 fb = 2607.5 psi > Fbx' = 2400.0 psi  (CSI = 1.09)   ➜  NG
12/21/2021 4
fv* = = 185.18 psi
 fv* = 185.18 psi < Fvx' = 265.00 psi  (CSI = 0.70)   ➜  OK
fv = = 223.49 psi
 fv = 223.49 psi < Fvx' = 265.00 psi  (CSI = 0.84)   ➜  OK
12/21/2021 5
ΔLL = = 0.00 in.
(L/d)LL = 140.00 / 0.00 = ∞
ΔTL = = 0.49 in.
(L/d)TL = 140.00 / 0.49 = 284
 ΔTL = 0.49 in = L/284 < L/120   ➜  OK
Ab = b x lb = 3.125 x 4 = 12.50 in2
fc⊥ = = 459.8 psi
 fc⊥ = 459.8 psi < Fc⊥x' = 650.00 psi  (CSI = 0.71)   ➜  OK
12/21/2021 6
