Size: 3.125 x 12
Design Span (L): 19.17 ft.
Clear Span: 18.83 ft.
Total Span: 19.50 ft.
Bearing (lb): 4 in.
Live Load: 219 plf
Dead Load: 219 plf
Selfweight: 168.5 lbs
Dist. Selfweight: 8.79 plf
Total Weight: 171.4 lbs
Beam Design 2021A768
12/21/2021 1
b = 3.125 in.
12/21/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [37.50 x (230.00 + 4)] x (12 in./ft.)3 = 5.08 ft3
Volumespan = N[A x L] = 1 x [37.50 x 230.00] x (12 in./ft.)3 = 4.99 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 5.08 = 171.4 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 4.99 = 168.5 lbs
219 plf
219 plf
  ws = 8.79 plf
19.17 ft.
18.83 ft.
19.50 ft.
4356.30 lbs
4356.30 lbs
12/21/2021 3
fb = = 3282.8 psi
 fb = 3282.8 psi > Fbx' = 2760.0 psi  (CSI = 1.19)   ➜  NG
12/21/2021 4
fv* = = 153.40 psi
 fv* = 153.40 psi < Fvx' = 304.75 psi  (CSI = 0.50)   ➜  OK
fv = = 171.27 psi
 fv = 171.27 psi < Fvx' = 304.75 psi  (CSI = 0.56)   ➜  OK
12/21/2021 5
ΔLL = = 0.82 in.
(L/d)LL = 230.00 / 0.82 = 280
 ΔLL = 0.82 in = L/280 > L/360   ➜  NG
ΔTL = = 1.68 in.
(L/d)TL = 230.00 / 1.68 = 137
 ΔTL = 1.68 in = L/137 > L/240   ➜  NG
Ab = b x lb = 3.125 x 4 = 12.50 in2
fc⊥ = = 348.5 psi
 fc⊥ = 348.5 psi < Fc⊥x' = 650.00 psi  (CSI = 0.54)   ➜  OK
12/21/2021 6
