Beam Design - 24ft Garage Roof Beam
Size: 5.5 x 10.5
Design Span (L): 23.54 ft.
Clear Span: 23.08 ft.
Total Span: 24.00 ft.
Bearing (lb): 5.5 in.
Selfweight: 318.8 lbs
Dist. Selfweight: 13.54 plf
Total Weight: 325.0 lbs
Notes: Deflection span/180, Due to T
CV Volume Factor 0.995b - - - - -
Beam Design Steve Frey 2021A767
12/21/2021 1
d = 10.500 in.
A = 5.500 x 10.500 = 57.75 in.2
Sx = (5.500)(10.500)2/6 = 101.06 in.3
Sy = (5.500)2(10.500)/6 = 52.94 in.3
Ix = (5.500)(10.500)3/12 = 530.58 in.4
Iy = (5.500)3(10.500)/12 = 145.58 in.4
12/21/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [57.75 x (282.50 + 5.5)] x (12 in./ft.)3 = 9.63 ft3
Volumespan = N[A x L] = 1 x [57.75 x 282.50] x (12 in./ft.)3 = 9.44 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 9.63 = 325.0 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 9.44 = 318.8 lbs
  ws = 13.54 plf
23.54 ft.
23.08 ft.
24.00 ft.
2262.51 lbs
2262.51 lbs
12/21/2021 3
CV = = 0.995
CV = 0.995 < CL = 1
Fbx' = (2400)(1.00)(1)(1)(0.995) = 2387.7 psi
fb = = 1550.9 psi
 fb = 1550.9 psi < Fbx' = 2387.7 psi  (CSI = 0.65)   ➜  OK
12/21/2021 4
fv* = = 53.36 psi
 fv* = 53.36 psi < Fvx' = 265.00 psi  (CSI = 0.20)   ➜  OK
fv = = 57.64 psi
 fv = 57.64 psi < Fvx' = 265.00 psi  (CSI = 0.22)   ➜  OK
12/21/2021 5
ΔLL = = 0.72 in.
(L/d)LL = 282.50 / 0.72 = 390
 ΔLL = 0.72 in = L/390 < L/180   ➜  OK
ΔTL = = 1.36 in.
(L/d)TL = 282.50 / 1.36 = 207
 ΔTL = 1.36 in = L/207 < L/120   ➜  OK
fc⊥ = = 74.8 psi
 fc⊥ = 74.8 psi < Fc⊥x' = 650.00 psi  (CSI = 0.12)   ➜  OK
12/21/2021 6
