Beam Design - Manda Spa
Species: Western Cedars
Grade: WC No.2
Size: 4 x 8
Design Span (L): 11.79 ft.
Total Span: 12.08 ft.
Bearing (lb): 3.5 in.
Live Load: 180 lbs
Dead Load: 25 lbs
Selfweight: 54.8 lbs
Dist. Selfweight: 4.65 plf
Total Weight: 56.1 lbs
Notes: Secondary Beam Analysis
CM Wet Service Factor 1b 1 0.97 1c 0.67 0.9
Ct Temperature Factor 0.7 0.9 0.7 0.7 0.7 0.9
CL Beam Stability Factor 0.986 - - - - -
Beam Design Dennis Lockhart 2 Jupiter Way 2021-002
12/21/2021 1
WC No.2 700 425 155 425 650 1000000 370000 0.36
G = 0.36
12/21/2021 2
= 26.36 lbs/ft3
Volumetotal = N[A x (L + lb)] = 1 x [25.38 x (141.50 + 3.5)] x (12 in./ft.)3 = 2.13 ft3
Volumespan = N[A x L] = 1 x [25.38 x 141.50] x (12 in./ft.)3 = 2.08 ft3
Total Weight (WT) = ρw x Volumetotal = 26.36 x 2.13 = 56.1 lbs
Self Weight (WS) = ρw x Volumespan = 26.36 x 2.08 = 54.8 lbs
Distributed Self Weight (ws) = = 4.65 plf
180 lbs
25 lbs
ws = 4.65 plf
11.79 ft.
12.08 ft.
130.57 lbs
130.57 lbs
12/21/2021 3
lu = Unbraced Length = 11.792 ft.
lu/d = = 19.52
le = 1.37lu + 3d = 1.37(141.5) + 3(7.25) = 215.61 in. = 17.97 ft.  (NDS Table 3.3.3)
Rb = = 11.30
 Rb = 11.30 < 50   ➜  OK
12/21/2021 4
Eminy' = Eminy(CM)(Ct)(Ci) = 370000(0.9)(0.9)(1) = 299700 psi
FbE = = 2818.36 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (700)(1.00)(1)(0.7)(1.3)(1)(1) = 637.00 psi
CL =   = 0.986
Fbx' = (700)(1.00)(1)(0.7)(0.986)(1.3)(1)(1) = 628.0 psi
fb = = 268.1 psi
 fb = 268.1 psi < Fbx' = 628.0 psi  (CSI = 0.43)   ➜  OK
Fvx' = (155)(1.00)(0.97)(0.7)(1) = 105.24 psi
fv* = = 7.51 psi
 fv* = 7.51 psi < Fvx' = 105.24 psi  (CSI = 0.07)   ➜  OK
fv = = 7.68 psi
 fv = 7.68 psi < Fvx' = 105.24 psi  (CSI = 0.07)   ➜  OK
12/21/2021 5
Ex' = Ex(CM)(Ct)(Ci) = 1000000(0.9)(0.9)(1) = 810000 psi
ΔLL =   =   = 0.12 in.
(L/d)LL = 141.50 / 0.12 = 1199
 ΔLL = 0.12 in = L/1199 < L/240   ➜  OK
ΔTL =   =   = 0.16 in.
(L/d)TL = 141.50 / 0.16 = 902
 ΔTL = 0.16 in = L/902 < L/180   ➜  OK
Fc⊥x' = (425)(0.67)(0.7)(1) = 199.32 psi
fc⊥ = = 10.7 psi
 fc⊥ = 10.7 psi < Fc⊥x' = 199.32 psi  (CSI = 0.05)   ➜  OK
12/21/2021 6
