Species: Western Cedars
Grade: WC No.2
Size: 4 x 12
Design Span (L): 22.71 ft.
Clear Span: 22.42 ft.
Total Span: 23.00 ft.
Bearing (lb): 3.5 in.
Live Load: 180 lbs
Dead Load: 25 lbs
Selfweight: 163.7 lbs
Dist. Selfweight: 7.21 plf
Total Weight: 165.8 lbs
CM Wet Service Factor 1b 1 0.97 1c 0.67 0.9
Ct Temperature Factor 0.7 0.9 0.7 0.7 0.7 0.9
CL Beam Stability Factor 0.947 - - - - -
CF Size Factor 1.1 1 - 1 - -
Beam Design 2021A763
12/21/2021 1
WC No.2 700 425 155 425 650 1000000 370000 0.36
G = 0.36
12/21/2021 2
= 26.36 lbs/ft3
Volumetotal = N[A x (L + lb)] = 1 x [39.38 x (272.50 + 3.5)] x (12 in./ft.)3 = 6.29 ft3
Volumespan = N[A x L] = 1 x [39.38 x 272.50] x (12 in./ft.)3 = 6.21 ft3
Total Weight (WT) = ρw x Volumetotal = 26.36 x 6.29 = 165.8 lbs
Self Weight (WS) = ρw x Volumespan = 26.36 x 6.21 = 163.7 lbs
Distributed Self Weight (ws) = = 7.21 plf
180 lbs
25 lbs
ws = 7.21 plf
22.71 ft.
22.42 ft.
23.00 ft.
185.40 lbs
185.40 lbs
12/21/2021 3
lu = Unbraced Length = 22.708 ft.
lu/d = = 24.22
le = 1.37lu + 3d = 1.37(272.5) + 3(11.25) = 407.07 in. = 33.92 ft.  (NDS Table 3.3.3)
Rb = = 19.33
 Rb = 19.33 < 50   ➜  OK
12/21/2021 4
Eminy' = Eminy(CM)(Ct)(Ci) = 370000(0.9)(0.9)(1) = 299700 psi
FbE = = 962.02 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (700)(1.00)(1)(0.7)(1.1)(1)(1) = 539.00 psi
CL =   = 0.947
Fbx' = (700)(1.00)(1)(0.7)(0.947)(1.1)(1)(1) = 510.2 psi
fb = = 264.7 psi
 fb = 264.7 psi < Fbx' = 510.2 psi  (CSI = 0.52)   ➜  OK
Fvx' = (155)(1.00)(0.97)(0.7)(1) = 105.24 psi
fv* = = 6.77 psi
 fv* = 6.77 psi < Fvx' = 105.24 psi  (CSI = 0.06)   ➜  OK
fv = = 7.02 psi
 fv = 7.02 psi < Fvx' = 105.24 psi  (CSI = 0.07)   ➜  OK
12/21/2021 5
Ex' = Ex(CM)(Ct)(Ci) = 1000000(0.9)(0.9)(1) = 810000 psi
ΔLL =   =   = 0.23 in.
(L/d)LL = 272.50 / 0.23 = 1208
 ΔLL = 0.23 in = L/1208 < L/240   ➜  OK
ΔTL =   =   = 0.39 in.
(L/d)TL = 272.50 / 0.39 = 708
 ΔTL = 0.39 in = L/708 < L/180   ➜  OK
Fc⊥x' = (425)(0.67)(0.7)(1) = 199.32 psi
fc⊥ = = 15.1 psi
 fc⊥ = 15.1 psi < Fc⊥x' = 199.32 psi  (CSI = 0.08)   ➜  OK
12/21/2021 6
