Size: 3.5 x 15
Design Span (L): 19.50 ft.
Clear Span: 19.00 ft.
Total Span: 20.00 ft.
Live Load: 20 plf
Dead Load: 280 plf
Selfweight: 240.0 lbs
Dist. Selfweight: 12.31 plf
Total Weight: 246.2 lbs
Beam Design 2021A761
12/20/2021 1
d = 15.000 in.
12/20/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [52.50 x (234.00 + 6)] x (12 in./ft.)3 = 7.29 ft3
Volumespan = N[A x L] = 1 x [52.50 x 234.00] x (12 in./ft.)3 = 7.11 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 7.29 = 246.2 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 7.11 = 240.0 lbs
20 plf
280 plf
  ws = 12.31 plf
19.50 ft.
19.00 ft.
3123.09 lbs
3123.09 lbs
12/20/2021 3
fb = = 1357.2 psi
 fb = 1357.2 psi < Fbx' = 2760.0 psi  (CSI = 0.49)   ➜  OK
12/20/2021 4
fv* = = 75.85 psi
 fv* = 75.85 psi < Fvx' = 304.75 psi  (CSI = 0.25)   ➜  OK
fv = = 87.00 psi
 fv = 87.00 psi < Fvx' = 304.75 psi  (CSI = 0.29)   ➜  OK
12/20/2021 5
ΔLL = = 0.04 in.
(L/d)LL = 234.00 / 0.04 = 6372
 ΔLL = 0.04 in = L/6372 < L/360   ➜  OK
ΔTL = = 0.57 in.
(L/d)TL = 234.00 / 0.57 = 408
 ΔTL = 0.57 in = L/408 < L/240   ➜  OK
fc⊥ = = 148.7 psi
 fc⊥ = 148.7 psi < Fc⊥x' = 650.00 psi  (CSI = 0.23)   ➜  OK
12/20/2021 6
