Grade: DF SS
Design Span (L): 7.25 ft.
Clear Span: 7.00 ft.
Total Span: 7.50 ft.
Live Load: 0 plf
Dead Load: 118 plf
Selfweight: 37.5 lbs
Dist. Selfweight: 5.17 plf
Total Weight: 38.7 lbs
Beam Design 2021A760
12/20/2021 1
12/20/2021 2
Volumetotal = N[A x (L + lb)] = 2 x [10.88 x (87.00 + 3)] x (12 in./ft.)3 = 1.13 ft3
Volumespan = N[A x L] = 2 x [10.88 x 87.00] x (12 in./ft.)3 = 1.10 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 1.13 = 38.7 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 1.10 = 37.5 lbs
0 plf
118 plf
ws = 5.17 plf
7.25 ft.
7.00 ft.
7.50 ft.
461.87 lbs
461.87 lbs
12/20/2021 3
lu = Unbraced Length = 7.250 ft.
lu/d = = 12.00
le = 1.63lu + 3d = 1.63(87.0) + 3(7.25) = 163.56 in. = 13.63 ft.  (NDS Table 3.3.3)
Rb = = 11.48
 Rb = 11.48 < 50   ➜  OK
12/20/2021 4
FbE = = 6284.31 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (1500)(0.9)(1)(1)(1.2)(1)(1) = 1620.00 psi
CL =   = 0.983
Fbx' = (1500)(0.9)(1)(1)(0.983)(1.2)(1)(1) = 1593.0 psi
fb = = 369.5 psi
 fb = 369.5 psi < Fbx' = 1593.0 psi  (CSI = 0.23)   ➜  OK
fv* = = 25.66 psi
 fv* = 25.66 psi < Fvx' = 162.00 psi  (CSI = 0.16)   ➜  OK
fv = = 30.79 psi
 fv = 30.79 psi < Fvx' = 162.00 psi  (CSI = 0.19)   ➜  OK
12/20/2021 5
ΔLL = = 0.00 in.
(L/d)LL = 87.00 / 0.00 = ∞
ΔTL = = 0.04 in.
(L/d)TL = 87.00 / 0.04 = 2057
 ΔTL = 0.04 in = L/2057 < L/240   ➜  OK
fc⊥ = = 51.3 psi
 fc⊥ = 51.3 psi < Fc⊥x' = 625.00 psi  (CSI = 0.08)   ➜  OK
12/20/2021 6
