Design Span (L): 5.00 ft.
Clear Span: 4.75 ft.
Total Span: 5.25 ft.
Live Load: 300 plf
Selfweight: 14.1 lbs
Dist. Selfweight: 2.82 plf
Total Weight: 14.8 lbs
Beam Design 2021A758
12/17/2021 1
12/17/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [10.88 x (60.00 + 3)] x (12 in./ft.)3 = 0.40 ft3
Volumespan = N[A x L] = 1 x [10.88 x 60.00] x (12 in./ft.)3 = 0.38 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 0.40 = 14.8 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 0.38 = 14.1 lbs
Distributed Self Weight (ws) = = 2.82 plf
300 plf
ws = 2.82 plf
5.00 ft.
4.75 ft.
5.25 ft.
991.78 lbs
991.78 lbs
12/17/2021 3
Fbx' = (925)(1.00)(1)(1)(1)(1)(1)(1) = 925.0 psi
fb = = 1078.2 psi
 fb = 1078.2 psi > Fbx' = 925.0 psi  (CSI = 1.17)   ➜  NG
12/17/2021 4
fv* = = 98.80 psi
 fv* = 98.80 psi < Fvx' = 175.00 psi  (CSI = 0.56)   ➜  OK
fv = = 130.28 psi
 fv = 130.28 psi < Fvx' = 175.00 psi  (CSI = 0.74)   ➜  OK
12/17/2021 5
ΔLL = = 0.06 in.
(L/d)LL = 60.00 / 0.06 = 948
 ΔLL = 0.06 in = L/948 < L/360   ➜  OK
ΔTL = = 0.08 in.
(L/d)TL = 60.00 / 0.08 = 753
 ΔTL = 0.08 in = L/753 < L/240   ➜  OK
fc⊥ = = 220.4 psi
 fc⊥ = 220.4 psi < Fc⊥x' = 565.00 psi  (CSI = 0.39)   ➜  OK
12/17/2021 6
