Design Span (L): 7.59 ft.
Clear Span: 7.34 ft.
Total Span: 7.84 ft.
Live Load: plf
Dead Load: 593 plf
Selfweight: 60.8 lbs
Dist. Selfweight: 8.02 plf
Total Weight: 62.8 lbs
CL Beam Stability Factor 0.980 - - - - -
Beam Design 2021A756
12/16/2021 1
12/16/2021 2
Volumetotal = N[A x (L + lb)] = 2 x [16.88 x (91.08 + 3)] x (12 in./ft.)3 = 1.84 ft3
Volumespan = N[A x L] = 2 x [16.88 x 91.08] x (12 in./ft.)3 = 1.78 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 1.84 = 62.8 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 1.78 = 60.8 lbs
plf
593 plf
ws = 8.02 plf
7.59 ft.
7.34 ft.
7.84 ft.
2355.98 lbs
2355.98 lbs
12/16/2021 3
lu = Unbraced Length = 7.590 ft.
lu/d = = 8.10
le = 1.63lu + 3d = 1.63(91.1) + 3(11.25) = 182.21 in. = 15.18 ft.  (NDS Table 3.3.3)
Rb = = 15.09
 Rb = 15.09 < 50   ➜  OK
12/16/2021 4
FbE = = 3055.81 psi
CL =   = 0.980
Fbx' = (900)(1.00)(1)(1)(0.980)(1)(1)(1) = 882.1 psi
fb = = 820.7 psi
 fb = 820.7 psi < Fbx' = 882.1 psi  (CSI = 0.93)   ➜  OK
fv* = = 76.33 psi
 fv* = 76.33 psi < Fvx' = 180.00 psi  (CSI = 0.42)   ➜  OK
fv = = 101.37 psi
 fv = 101.37 psi < Fvx' = 180.00 psi  (CSI = 0.56)   ➜  OK
12/16/2021 5
ΔLL = = 0.00 in.
(L/d)LL = 91.08 / 0.00 = ∞
ΔTL = = 0.08 in.
(L/d)TL = 91.08 / 0.08 = 1156
 ΔTL = 0.08 in = L/1156 < L/240   ➜  OK
fc⊥ = = 261.8 psi
 fc⊥ = 261.8 psi < Fc⊥x' = 625.00 psi  (CSI = 0.42)   ➜  OK
12/16/2021 6
