Size: 3.5 x 13.5
Design Span (L): 20.25 ft.
Clear Span: 20.00 ft.
Total Span: 20.50 ft.
Live Load: 280 plf
Dead Load: 105 plf
Selfweight: 224.3 lbs
Dist. Selfweight: 11.08 plf
Total Weight: 227.1 lbs
Beam Design 2021A754
12/16/2021 1
d = 13.500 in.
A = 3.500 x 13.500 = 47.25 in.2
Sx = (3.500)(13.500)2/6 = 106.31 in.3
Sy = (3.500)2(13.500)/6 = 27.56 in.3
Ix = (3.500)(13.500)3/12 = 717.61 in.4
Iy = (3.500)3(13.500)/12 = 48.23 in.4
12/16/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [47.25 x (243.00 + 3)] x (12 in./ft.)3 = 6.73 ft3
Volumespan = N[A x L] = 1 x [47.25 x 243.00] x (12 in./ft.)3 = 6.64 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 6.73 = 227.1 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 6.64 = 224.3 lbs
Distributed Self Weight (ws) = = 11.08 plf
280 plf
105 plf
  ws = 11.08 plf
20.25 ft.
20.50 ft.
4059.80 lbs
4059.80 lbs
12/16/2021 3
fb = = 2291.6 psi
 fb = 2291.6 psi < Fbx' = 2400.0 psi  (CSI = 0.95)   ➜  OK
12/16/2021 4
fv* = = 113.17 psi
 fv* = 113.17 psi < Fvx' = 265.00 psi  (CSI = 0.43)   ➜  OK
fv = = 127.31 psi
 fv = 127.31 psi < Fvx' = 265.00 psi  (CSI = 0.48)   ➜  OK
12/16/2021 5
ΔLL = = 0.82 in.
(L/d)LL = 243.00 / 0.82 = 296
 ΔLL = 0.82 in = L/296 > L/360   ➜  NG
ΔTL = = 1.16 in.
(L/d)TL = 243.00 / 1.16 = 209
 ΔTL = 1.16 in = L/209 > L/240   ➜  NG
fc⊥ = = 386.6 psi
 fc⊥ = 386.6 psi < Fc⊥x' = 650.00 psi  (CSI = 0.59)   ➜  OK
12/16/2021 6
