Design Span (L): 8.75 ft.
Clear Span: 8.50 ft.
Total Span: 9.00 ft.
Live Load: 31.25 plf
Dead Load: 6.25 plf
Selfweight: 17.1 lbs
Dist. Selfweight: 1.96 plf
Total Weight: 17.6 lbs
Beam Design 2021A751
12/15/2021 1
12/15/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [8.25 x (105.00 + 3)] x (12 in./ft.)3 = 0.52 ft3
Volumespan = N[A x L] = 1 x [8.25 x 105.00] x (12 in./ft.)3 = 0.50 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 0.52 = 17.6 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 0.50 = 17.1 lbs
31.25 plf
6.25 plf
ws = 1.96 plf
8.75 ft.
8.50 ft.
9.00 ft.
177.57 lbs
177.57 lbs
12/15/2021 3
fb = = 599.2 psi
 fb = 599.2 psi < Fbx' = 1345.5 psi  (CSI = 0.45)   ➜  OK
12/15/2021 4
fv* = = 28.10 psi
 fv* = 28.10 psi < Fvx' = 207.00 psi  (CSI = 0.14)   ➜  OK
fv = = 31.39 psi
 fv = 31.39 psi < Fvx' = 207.00 psi  (CSI = 0.15)   ➜  OK
12/15/2021 5
ΔLL = = 0.12 in.
(L/d)LL = 105.00 / 0.12 = 848
 ΔLL = 0.12 in = L/848 < L/360   ➜  OK
ΔTL = = 0.16 in.
(L/d)TL = 105.00 / 0.16 = 671
 ΔTL = 0.16 in = L/671 < L/240   ➜  OK
fc⊥ = = 39.5 psi
 fc⊥ = 39.5 psi < Fc⊥x' = 625.00 psi  (CSI = 0.06)   ➜  OK
12/15/2021 6
