Design Span (L): 8.75 ft.
Clear Span: 8.50 ft.
Total Span: 9.00 ft.
Live Load: 25 plf
Dead Load: 5 plf
Selfweight: 17.1 lbs
Dist. Selfweight: 1.96 plf
Total Weight: 17.6 lbs
Beam Design 2021A750
12/15/2021 1
12/15/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [8.25 x (105.00 + 3)] x (12 in./ft.)3 = 0.52 ft3
Volumespan = N[A x L] = 1 x [8.25 x 105.00] x (12 in./ft.)3 = 0.50 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 0.52 = 17.6 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 0.50 = 17.1 lbs
25 plf
5 plf
ws = 1.96 plf
8.75 ft.
8.50 ft.
9.00 ft.
143.82 lbs
143.82 lbs
12/15/2021 3
fb = = 485.3 psi
 fb = 485.3 psi < Fbx' = 1345.5 psi  (CSI = 0.36)   ➜  OK
12/15/2021 4
fv* = = 22.76 psi
 fv* = 22.76 psi < Fvx' = 207.00 psi  (CSI = 0.11)   ➜  OK
fv = = 25.42 psi
 fv = 25.42 psi < Fvx' = 207.00 psi  (CSI = 0.12)   ➜  OK
12/15/2021 5
ΔLL = = 0.10 in.
(L/d)LL = 105.00 / 0.10 = 1060
 ΔLL = 0.10 in = L/1060 < L/180   ➜  OK
ΔTL = = 0.13 in.
(L/d)TL = 105.00 / 0.13 = 829
 ΔTL = 0.13 in = L/829 < L/120   ➜  OK
fc⊥ = = 32.0 psi
 fc⊥ = 32.0 psi < Fc⊥x' = 625.00 psi  (CSI = 0.05)   ➜  OK
12/15/2021 6
