Design Span (L): 7.75 ft.
Clear Span: 7.50 ft.
Total Span: 8.00 ft.
Live Load: plf
Dead Load: 470 plf
Selfweight: 62.1 lbs
Dist. Selfweight: 8.02 plf
Total Weight: 64.1 lbs
Beam Design 2021A748
12/15/2021 1
12/15/2021 2
Total Weight (WT) = ρw x Volumetotal = 34.20 x 1.88 = 64.1 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 1.82 = 62.1 lbs
plf
470 plf
ws = 8.02 plf
7.75 ft.
7.50 ft.
1912.07 lbs
1912.07 lbs
12/15/2021 3
fb = = 680.6 psi
 fb = 680.6 psi < Fbx' = 900.0 psi  (CSI = 0.76)   ➜  OK
12/15/2021 4
fv* = = 62.41 psi
 fv* = 62.41 psi < Fvx' = 180.00 psi  (CSI = 0.35)   ➜  OK
fv = = 82.33 psi
 fv = 82.33 psi < Fvx' = 180.00 psi  (CSI = 0.46)   ➜  OK
12/15/2021 5
ΔLL = = 0.00 in.
(L/d)LL = 93.00 / 0.00 = ∞
ΔTL = = 0.07 in.
(L/d)TL = 93.00 / 0.07 = 1365
 ΔTL = 0.07 in = L/1365 < L/240   ➜  OK
fc⊥ = = 212.5 psi
 fc⊥ = 212.5 psi < Fc⊥x' = 625.00 psi  (CSI = 0.34)   ➜  OK
12/15/2021 6
