Design Span (L): 17.54 ft.
Clear Span: 17.08 ft.
Total Span: 18.00 ft.
Bearing (lb): 5.5 in.
Live Load: 0 plf
Dead Load: 29.6 plf
Selfweight: 103.1 lbs
Dist. Selfweight: 5.88 plf
Total Weight: 105.8 lbs
Beam Design 2021A745
12/13/2021 1
12/13/2021 2
Volumetotal = N[A x (L + lb)] = 3 x [8.25 x (210.50 + 5.5)] x (12 in./ft.)3 = 3.09 ft3
Volumespan = N[A x L] = 3 x [8.25 x 210.50] x (12 in./ft.)3 = 3.02 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 3.09 = 105.8 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 3.02 = 103.1 lbs
Distributed Self Weight (ws) = = 5.88 plf
0 plf
29.6 plf
ws = 5.88 plf
17.54 ft.
17.08 ft.
18.00 ft.
319.31 lbs
319.31 lbs
12/13/2021 3
Fbx' = (900)(0.9)(1)(1)(1)(1.3)(1)(1) = 1053.0 psi
fb = = 721.8 psi
 fb = 721.8 psi < Fbx' = 1053.0 psi  (CSI = 0.69)   ➜  OK
12/13/2021 4
fv* = = 17.87 psi
 fv* = 17.87 psi < Fvx' = 162.00 psi  (CSI = 0.11)   ➜  OK
fv = = 18.86 psi
 fv = 18.86 psi < Fvx' = 162.00 psi  (CSI = 0.12)   ➜  OK
12/13/2021 5
ΔLL = = 0.00 in.
(L/d)LL = 210.50 / 0.00 = ∞
ΔTL = = 0.76 in.
(L/d)TL = 210.50 / 0.76 = 278
 ΔTL = 0.76 in = L/278 < L/240   ➜  OK
fc⊥ = = 12.9 psi
 fc⊥ = 12.9 psi < Fc⊥x' = 625.00 psi  (CSI = 0.02)   ➜  OK
12/13/2021 6
