Beam Design - 16736 Addition
Grade: SP No.1
Design Span (L): 7.25 ft.
Clear Span: 7.00 ft.
Total Span: 7.50 ft.
Live Load: 60 plf
Dead Load: 50 plf
Selfweight: 15.5 lbs
Dist. Selfweight: 2.14 plf
Total Weight: 16.0 lbs
Lateral Support: 4' o/c
Notes: Beam over existing roof.
CL Beam Stability Factor 0.963 - - - - -
Beam Design Aaron McDaniel 16736 123 Ter N 2021-1
1/17/2021 1
SP No.1 1350 875 175 565 1550 1600000 580000 0.55
1/17/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [8.25 x (87.00 + 3)] x (12 in./ft.)3 = 0.43 ft3
Volumespan = N[A x L] = 1 x [8.25 x 87.00] x (12 in./ft.)3 = 0.42 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 0.43 = 16.0 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 0.42 = 15.5 lbs
Distributed Self Weight (ws) = = 2.14 plf
60 plf
50 plf
ws = 2.14 plf
7.25 ft.
7.00 ft.
7.50 ft.
420.52 lbs
420.52 lbs
1/17/2021 3
lu = Unbraced Length = 4 ft.
lu/d = = 8.73
le = 1.63lu + 3d = 1.63(48.0) + 3(5.5) = 94.74 in. = 7.89 ft.  (NDS Table 3.3.3)
Rb = = 15.22
 Rb = 15.22 < 50   ➜  OK
1/17/2021 4
FbE = = 3005.35 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (1350)(1.00)(1)(1)(1)(1)(1) = 1350.00 psi
CL =   = 0.963
Fbx' = (1350)(1.00)(1)(1)(0.963)(1)(1)(1) = 1300.4 psi
fb = = 1169.1 psi
 fb = 1169.1 psi < Fbx' = 1300.4 psi  (CSI = 0.90)   ➜  OK
fv* = = 64.56 psi
 fv* = 64.56 psi < Fvx' = 175.00 psi  (CSI = 0.37)   ➜  OK
fv = = 73.91 psi
 fv = 73.91 psi < Fvx' = 175.00 psi  (CSI = 0.42)   ➜  OK
1/17/2021 5
ΔLL = = 0.11 in.
(L/d)LL = 87.00 / 0.11 = 776
 ΔLL = 0.11 in = L/776 < L/360   ➜  OK
ΔTL = = 0.21 in.
(L/d)TL = 87.00 / 0.21 = 415
 ΔTL = 0.21 in = L/415 < L/240   ➜  OK
fc⊥ = = 93.4 psi
 fc⊥ = 93.4 psi < Fc⊥x' = 565.00 psi  (CSI = 0.17)   ➜  OK
1/17/2021 6
