Size: 4 x 4
Design Span (L): 8.25 ft.
Clear Span: 8.00 ft.
Total Span: 8.50 ft.
Live Load: 125 plf
Dead Load: 0 plf
Selfweight: 24.0 lbs
Dist. Selfweight: 2.91 plf
Total Weight: 24.7 lbs
Load Duration: 1.25
Beam Design 2021A739
12/13/2021 1
d = 3.500 in.
12/13/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [12.25 x (99.00 + 3)] x (12 in./ft.)3 = 0.72 ft3
Volumespan = N[A x L] = 1 x [12.25 x 99.00] x (12 in./ft.)3 = 0.70 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 0.72 = 24.7 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 0.70 = 24.0 lbs
125 plf
0 plf
ws = 2.91 plf
8.25 ft.
8.50 ft.
543.62 lbs
543.62 lbs
12/13/2021 3
Fbx' = (900)(1.25)(1)(1)(1)(1.5)(1)(1) = 1687.5 psi
fb = = 1827.5 psi
 fb = 1827.5 psi > Fbx' = 1687.5 psi  (CSI = 1.08)   ➜  NG
12/13/2021 4
fv* = = 60.04 psi
 fv* = 60.04 psi < Fvx' = 225.00 psi  (CSI = 0.27)   ➜  OK
fv = = 64.61 psi
 fv = 64.61 psi < Fvx' = 225.00 psi  (CSI = 0.29)   ➜  OK
12/13/2021 5
ΔLL = = 0.65 in.
(L/d)LL = 99.00 / 0.65 = 152
 ΔLL = 0.65 in = L/152 > L/360   ➜  NG
ΔTL = = 0.67 in.
(L/d)TL = 99.00 / 0.67 = 149
 ΔTL = 0.67 in = L/149 > L/240   ➜  NG
fc⊥ = = 51.8 psi
 fc⊥ = 51.8 psi < Fc⊥x' = 625.00 psi  (CSI = 0.08)   ➜  OK
12/13/2021 6
