Beam Design - Owens Stairway Opening
Design Span (L): 9.38 ft.
Clear Span: 9.00 ft.
Total Span: 9.75 ft.
Bearing (lb): 4.5 in.
Live Load: 300 plf
Dead Load: 200 plf
Selfweight: 92.7 lbs
Dist. Selfweight: 9.89 plf
Total Weight: 96.4 lbs
Beam Design Devan Owens 305 SE Derby St 2021A734
12/9/2021 1
12/9/2021 2
Volumetotal = N[A x (L + lb)] = 3 x [13.88 x (112.50 + 4.5)] x (12 in./ft.)3 = 2.82 ft3
Volumespan = N[A x L] = 3 x [13.88 x 112.50] x (12 in./ft.)3 = 2.71 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 2.82 = 96.4 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 2.71 = 92.7 lbs
300 plf
200 plf
ws = 9.89 plf
9.38 ft.
9.00 ft.
9.75 ft.
2485.70 lbs
2485.70 lbs
12/9/2021 3
fb = = 1047.5 psi
 fb = 1047.5 psi < Fbx' = 1138.5 psi  (CSI = 0.92)   ➜  OK
12/9/2021 4
fv* = = 71.97 psi
 fv* = 71.97 psi < Fvx' = 207.00 psi  (CSI = 0.35)   ➜  OK
fv = = 86.13 psi
 fv = 86.13 psi < Fvx' = 207.00 psi  (CSI = 0.42)   ➜  OK
12/9/2021 5
ΔLL = = 0.11 in.
(L/d)LL = 112.50 / 0.11 = 1025
 ΔLL = 0.11 in = L/1025 < L/240   ➜  OK
ΔTL = = 0.19 in.
(L/d)TL = 112.50 / 0.19 = 603
 ΔTL = 0.19 in = L/603 < L/180   ➜  OK
Ab = b x lb = 1.5 x 4.5 = 6.75 in2
fc⊥ = = 122.8 psi
 fc⊥ = 122.8 psi < Fc⊥x' = 625.00 psi  (CSI = 0.20)   ➜  OK
12/9/2021 6
