Design Span (L): 15.96 ft.
Clear Span: 15.67 ft.
Total Span: 16.25 ft.
Bearing (lb): 3.5 in.
Selfweight: 139.6 lbs
Dist. Selfweight: 8.75 plf
Total Weight: 142.2 lbs
CL Beam Stability Factor 0.949 - - - - -
Beam Design 2021A733
12/9/2021 1
12/9/2021 2
Volumetotal = N[A x (L + lb)] = 2 x [16.88 x (191.50 + 3.5)] x (12 in./ft.)3 = 3.81 ft3
Volumespan = N[A x L] = 2 x [16.88 x 191.50] x (12 in./ft.)3 = 3.74 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 3.81 = 142.2 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 3.74 = 139.6 lbs
ws = 8.75 plf
15.96 ft.
15.67 ft.
16.25 ft.
1492.93 lbs
1492.93 lbs
12/9/2021 3
lu = Unbraced Length = 14 ft.
lu/d = = 14.93
le = 1.84lu = 1.84(168.0) = 309.12 in. = 25.76 ft.  (NDS Table 3.3.3)
Rb = = 19.66
 Rb = 19.66 < 50   ➜  OK
12/9/2021 4
FbE = = 1583.85 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (750)(1.15)(1)(1)(1)(1)(1) = 862.50 psi
CL =   = 0.949
Fbx' = (750)(1.15)(1)(1)(0.949)(1)(1)(1) = 818.7 psi
fb = = 1109.2 psi
 fb = 1109.2 psi > Fbx' = 818.7 psi  (CSI = 1.35)   ➜  NG
fv* = = 57.51 psi
 fv* = 57.51 psi < Fvx' = 201.25 psi  (CSI = 0.29)   ➜  OK
fv = = 65.16 psi
 fv = 65.16 psi < Fvx' = 201.25 psi  (CSI = 0.32)   ➜  OK
12/9/2021 5
ΔLL = = 0.29 in.
(L/d)LL = 191.50 / 0.29 = 654
 ΔLL = 0.29 in = L/654 < L/180   ➜  OK
ΔTL = = 0.54 in.
(L/d)TL = 191.50 / 0.54 = 356
 ΔTL = 0.54 in = L/356 < L/120   ➜  OK
fc⊥ = = 142.2 psi
 fc⊥ = 142.2 psi < Fc⊥x' = 565.00 psi  (CSI = 0.25)   ➜  OK
12/9/2021 6
