Beam Design - 115 James Ave Orlando
Grade: SP No.1
Design Span (L): 7.30 ft.
Clear Span: 6.80 ft.
Total Span: 7.80 ft.
Live Load: 480 plf
Dead Load: 120 plf
Selfweight: 61.7 lbs
Dist. Selfweight: 8.46 plf
Total Weight: 66.0 lbs
Notes: Triple 2x8 Supplemental Beam
Beam Design 2021A731
12/6/2021 1
SP No.1 1250 800 175 565 1500 1600000 580000 0.55
12/6/2021 2
Volumetotal = N[A x (L + lb)] = 3 x [10.88 x (87.60 + 6)] x (12 in./ft.)3 = 1.77 ft3
Volumespan = N[A x L] = 3 x [10.88 x 87.60] x (12 in./ft.)3 = 1.65 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 1.77 = 66.0 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 1.65 = 61.7 lbs
Distributed Self Weight (ws) = = 8.46 plf
480 plf
120 plf
ws = 8.46 plf
7.30 ft.
6.80 ft.
7.80 ft.
2372.98 lbs
2372.98 lbs
12/6/2021 3
Fbx' = (1250)(1.00)(1)(1)(1)(1)(1)(1) = 1250.0 psi
fb = = 1233.8 psi
 fb = 1233.8 psi < Fbx' = 1250.0 psi  (CSI = 0.99)   ➜  OK
12/6/2021 4
fv* = = 85.21 psi
 fv* = 85.21 psi < Fvx' = 175.00 psi  (CSI = 0.49)   ➜  OK
fv = = 102.11 psi
 fv = 102.11 psi < Fvx' = 175.00 psi  (CSI = 0.58)   ➜  OK
12/6/2021 5
ΔLL = = 0.13 in.
(L/d)LL = 87.60 / 0.13 = 653
 ΔLL = 0.13 in = L/653 < L/180   ➜  OK
ΔTL = = 0.17 in.
(L/d)TL = 87.60 / 0.17 = 515
 ΔTL = 0.17 in = L/515 < L/120   ➜  OK
fc⊥ = = 87.9 psi
 fc⊥ = 87.9 psi < Fc⊥x' = 565.00 psi  (CSI = 0.16)   ➜  OK
12/6/2021 6
