Beam Design - 16736 Addition
Grade: SP No.1
Design Span (L): 6.75 ft.
Clear Span: 6.50 ft.
Total Span: 7.00 ft.
Live Load: 30 plf
Dead Load: 25 plf
Selfweight: 14.4 lbs
Dist. Selfweight: 2.14 plf
Total Weight: 15.0 lbs
Beam Design Aaron McDaniel 16736 123 Ter N 2021-1
1/17/2021 1
SP No.1 1350 875 175 565 1550 1600000 580000 0.55
1/17/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [8.25 x (81.00 + 3)] x (12 in./ft.)3 = 0.40 ft3
Volumespan = N[A x L] = 1 x [8.25 x 81.00] x (12 in./ft.)3 = 0.39 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 0.40 = 15.0 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 0.39 = 14.4 lbs
Distributed Self Weight (ws) = = 2.14 plf
30 plf
25 plf
ws = 2.14 plf
6.75 ft.
6.50 ft.
7.00 ft.
199.99 lbs
199.99 lbs
1/17/2021 3
Fbx' = (1350)(1.00)(1)(1)(1)(1)(1)(1) = 1350.0 psi
fb = = 516.4 psi
 fb = 516.4 psi < Fbx' = 1350.0 psi  (CSI = 0.38)   ➜  OK
1/17/2021 4
fv* = = 30.30 psi
 fv* = 30.30 psi < Fvx' = 175.00 psi  (CSI = 0.17)   ➜  OK
fv = = 35.06 psi
 fv = 35.06 psi < Fvx' = 175.00 psi  (CSI = 0.20)   ➜  OK
1/17/2021 5
ΔLL = = 0.04 in.
(L/d)LL = 81.00 / 0.04 = 1923
 ΔLL = 0.04 in = L/1923 < L/360   ➜  OK
ΔTL = = 0.08 in.
(L/d)TL = 81.00 / 0.08 = 1010
 ΔTL = 0.08 in = L/1010 < L/240   ➜  OK
fc⊥ = = 44.4 psi
 fc⊥ = 44.4 psi < Fc⊥x' = 565.00 psi  (CSI = 0.08)   ➜  OK
1/17/2021 6
