Grade: SP No.1
Design Span (L): 11.58 ft.
Clear Span: 11.17 ft.
Bearing (lb): 5 in.
Selfweight: 41.7 lbs
Dist. Selfweight: 3.60 plf
Total Weight: 43.2 lbs
Lateral Support: 4' o/c
Load Duration: 1.25
CL Beam Stability Factor 0.900 - - - - -
Beam Design 2x10 SUPPORT
12/6/2021 1
12/6/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [13.88 x (139.00 + 5)] x (12 in./ft.)3 = 1.16 ft3
Volumespan = N[A x L] = 1 x [13.88 x 139.00] x (12 in./ft.)3 = 1.12 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 1.16 = 43.2 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 1.12 = 41.7 lbs
ws = 3.60 plf
11.58 ft.
11.17 ft.
1071.55 lbs
1071.55 lbs
12/6/2021 3
lu = Unbraced Length = 4 ft.
lu/d = = 5.19
Rb = = 20.16
 Rb = 20.16 < 50   ➜  OK
12/6/2021 4
FbE = = 1712.15 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (1050)(1.25)(1)(1)(1)(1)(1) = 1312.50 psi
CL =   = 0.900
Fbx' = (1050)(1.25)(1)(1)(0.900)(1)(1)(1) = 1181.1 psi
fb = = 1680.3 psi
 fb = 1680.3 psi > Fbx' = 1181.1 psi  (CSI = 1.42)   ➜  NG
Fvx' = (175)(1.25)(1)(1)(1) = 218.75 psi
fv* = = 96.94 psi
 fv* = 96.94 psi < Fvx' = 218.75 psi  (CSI = 0.44)   ➜  OK
fv = = 111.82 psi
 fv = 111.82 psi < Fvx' = 218.75 psi  (CSI = 0.51)   ➜  OK
12/6/2021 5
ΔLL = = 0.26 in.
(L/d)LL = 139.00 / 0.26 = 543
 ΔLL = 0.26 in = L/543 < L/360   ➜  OK
ΔTL = = 0.46 in.
(L/d)TL = 139.00 / 0.46 = 304
 ΔTL = 0.46 in = L/304 < L/240   ➜  OK
Ab = b x lb = 1.5 x 5 = 7.50 in2
fc⊥ = = 142.9 psi
 fc⊥ = 142.9 psi < Fc⊥x' = 565.00 psi  (CSI = 0.25)   ➜  OK
12/6/2021 6
