Design Span (L): 15.58 ft.
Clear Span: 15.17 ft.
Total Span: 16.00 ft.
Bearing (lb): 5 in.
Live Load: 20 plf
Dead Load: 15 plf
Selfweight: 187.4 lbs
Dist. Selfweight: 12.02 plf
Total Weight: 192.4 lbs
Beam Design Ramon Munoz 1516 N Magnolia Ave Muņoz Addition
12/6/2021 1
12/6/2021 2
Volumetotal = N[A x (L + lb)] = 3 x [16.88 x (187.00 + 5)] x (12 in./ft.)3 = 5.62 ft3
Volumespan = N[A x L] = 3 x [16.88 x 187.00] x (12 in./ft.)3 = 5.48 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 5.62 = 192.4 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 5.48 = 187.4 lbs
20 plf
15 plf
ws = 12.02 plf
15.58 ft.
15.17 ft.
376.19 lbs
376.19 lbs
12/6/2021 3
fb = = 180.4 psi
 fb = 180.4 psi < Fbx' = 900.0 psi  (CSI = 0.20)   ➜  OK
12/6/2021 4
fv* = = 9.55 psi
 fv* = 9.55 psi < Fvx' = 180.00 psi  (CSI = 0.05)   ➜  OK
fv = = 10.86 psi
 fv = 10.86 psi < Fvx' = 180.00 psi  (CSI = 0.06)   ➜  OK
12/6/2021 5
ΔLL = = 0.03 in.
(L/d)LL = 187.00 / 0.03 = 6020
 ΔLL = 0.03 in = L/6020 < L/240   ➜  OK
ΔTL = = 0.07 in.
(L/d)TL = 187.00 / 0.07 = 2561
 ΔTL = 0.07 in = L/2561 < L/180   ➜  OK
Ab = b x lb = 1.5 x 5 = 7.50 in2
fc⊥ = = 16.7 psi
 fc⊥ = 16.7 psi < Fc⊥x' = 625.00 psi  (CSI = 0.03)   ➜  OK
12/6/2021 6
