Beam Design - Cooley Residence
Grade: SP No.1
Design Span (L): 7.92 ft.
Clear Span: 7.83 ft.
Total Span: 8.00 ft.
Bearing (lb): 1 in.
Selfweight: 34.6 lbs
Dist. Selfweight: 4.37 plf
Total Weight: 35.0 lbs
Beam Design 2021A724
12/6/2021 1
12/6/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [16.88 x (95.00 + 1)] x (12 in./ft.)3 = 0.94 ft3
Volumespan = N[A x L] = 1 x [16.88 x 95.00] x (12 in./ft.)3 = 0.93 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 0.94 = 35.0 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 0.93 = 34.6 lbs
ws = 4.37 plf
7.92 ft.
7.83 ft.
717.53 lbs
717.53 lbs
12/6/2021 3
fb = = 533.0 psi
 fb = 533.0 psi < Fbx' = 1150.0 psi  (CSI = 0.46)   ➜  OK
12/6/2021 4
fv* = = 48.17 psi
 fv* = 48.17 psi < Fvx' = 201.25 psi  (CSI = 0.24)   ➜  OK
fv = = 63.12 psi
 fv = 63.12 psi < Fvx' = 201.25 psi  (CSI = 0.31)   ➜  OK
12/6/2021 5
ΔLL = = 0.03 in.
(L/d)LL = 95.00 / 0.03 = 3061
 ΔLL = 0.03 in = L/3061 < L/180   ➜  OK
ΔTL = = 0.06 in.
(L/d)TL = 95.00 / 0.06 = 1706
 ΔTL = 0.06 in = L/1706 < L/120   ➜  OK
Ab = b x lb = 1.5 x 1 = 1.50 in2
fc⊥ = = 478.4 psi
 fc⊥ = 478.4 psi < Fc⊥x' = 565.00 psi  (CSI = 0.85)   ➜  OK
12/6/2021 6
