Grade: 24F-V5 1.7E DF/HF
Size: 3.5 x 15
Design Span (L): 20.25 ft.
Clear Span: 20.00 ft.
Total Span: 20.50 ft.
Live Load: 390 plf
Dead Load: 120 plf
Selfweight: 249.3 lbs
Dist. Selfweight: 12.31 plf
Total Weight: 252.3 lbs
Beam Design 2021A723
12/6/2021 1
d = 15.000 in.
24F-V5 1.7E DF/HF 2400 1600 650 215 1700000 900000 1350 375 200 1500000 790000 1100 1450 0.5
12/6/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [52.50 x (243.00 + 3)] x (12 in./ft.)3 = 7.47 ft3
Volumespan = N[A x L] = 1 x [52.50 x 243.00] x (12 in./ft.)3 = 7.38 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 7.47 = 252.3 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 7.38 = 249.3 lbs
390 plf
120 plf
  ws = 12.31 plf
20.25 ft.
20.50 ft.
5353.66 lbs
5353.66 lbs
12/6/2021 3
fb = = 2447.8 psi
 fb = 2447.8 psi < Fbx' = 2760.0 psi  (CSI = 0.89)   ➜  OK
12/6/2021 4
Fvx' = (215)(1.15)(1)(1) = 247.25 psi
fv* = = 132.44 psi
 fv* = 132.44 psi < Fvx' = 247.25 psi  (CSI = 0.54)   ➜  OK
fv = = 151.10 psi
 fv = 151.10 psi < Fvx' = 247.25 psi  (CSI = 0.61)   ➜  OK
Ex' = Ex(CM)(Ct) = 1700000(1)(1) = 1700000 psi
12/6/2021 5
ΔLL = = 0.88 in.
(L/d)LL = 243.00 / 0.88 = 276
 ΔLL = 0.88 in = L/276 < L/180   ➜  OK
ΔTL = = 1.18 in.
(L/d)TL = 243.00 / 1.18 = 206
 ΔTL = 1.18 in = L/206 < L/120   ➜  OK
fc⊥ = = 509.9 psi
 fc⊥ = 509.9 psi < Fc⊥x' = 650.00 psi  (CSI = 0.78)   ➜  OK
12/6/2021 6
