Grade: SPF SS
Design Span (L): 2.38 ft.
Clear Span: 2.25 ft.
Total Span: 2.50 ft.
Bearing (lb): 1.5 in.
Live Load: 505 plf
Dead Load: 105 plf
Selfweight: 7.9 lbs
Dist. Selfweight: 3.33 plf
Total Weight: 8.3 lbs
Beam Design 2021A722
12/5/2021 1
12/5/2021 2
Volumetotal = N[A x (L + lb)] = 2 x [8.25 x (28.50 + 1.5)] x (12 in./ft.)3 = 0.29 ft3
Volumespan = N[A x L] = 2 x [8.25 x 28.50] x (12 in./ft.)3 = 0.27 ft3
Total Weight (WT) = ρw x Volumetotal = 29.10 x 0.29 = 8.3 lbs
Self Weight (WS) = ρw x Volumespan = 29.10 x 0.27 = 7.9 lbs
Distributed Self Weight (ws) = = 3.33 plf
505 plf
105 plf
ws = 3.33 plf
2.38 ft.
2.25 ft.
2.50 ft.
766.67 lbs
766.67 lbs
12/5/2021 3
lu = Unbraced Length = 2.375 ft.
lu/d = = 5.18
le = 2.06lu = 2.06(28.5) = 58.71 in. = 4.89 ft.  (NDS Table 3.3.3)
Rb = = 5.99
 Rb = 5.99 < 50   ➜  OK
12/5/2021 4
FbE = = 18395.50 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (1250)(1.15)(1)(1)(1.3)(1)(1) = 1868.75 psi
CL =   = 0.994
Fbx' = (1250)(1.15)(1)(1)(0.994)(1.3)(1)(1) = 1858.3 psi
fb = = 343.1 psi
 fb = 343.1 psi < Fbx' = 1858.3 psi  (CSI = 0.18)   ➜  OK
fv* = = 40.66 psi
 fv* = 40.66 psi < Fvx' = 155.25 psi  (CSI = 0.26)   ➜  OK
fv = = 66.21 psi
 fv = 66.21 psi < Fvx' = 155.25 psi  (CSI = 0.43)   ➜  OK
12/5/2021 5
ΔLL = = 0.01 in.
(L/d)LL = 28.50 / 0.01 = 4919
 ΔLL = 0.01 in = L/4919 < L/360   ➜  OK
ΔTL = = 0.01 in.
(L/d)TL = 28.50 / 0.01 = 4050
 ΔTL = 0.01 in = L/4050 < L/240   ➜  OK
fc⊥ = = 170.4 psi
 fc⊥ = 170.4 psi < Fc⊥x' = 425.00 psi  (CSI = 0.40)   ➜  OK
12/5/2021 6
