Design Span (L): 2.38 ft.
Clear Span: 2.25 ft.
Total Span: 2.50 ft.
Bearing (lb): 1.5 in.
Live Load: 550 plf
Dead Load: 110 plf
Selfweight: 9.3 lbs
Dist. Selfweight: 3.92 plf
Total Weight: 9.8 lbs
Beam Design 2021A721
12/5/2021 1
12/5/2021 2
Volumetotal = N[A x (L + lb)] = 2 x [8.25 x (28.50 + 1.5)] x (12 in./ft.)3 = 0.29 ft3
Volumespan = N[A x L] = 2 x [8.25 x 28.50] x (12 in./ft.)3 = 0.27 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 0.29 = 9.8 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 0.27 = 9.3 lbs
550 plf
110 plf
ws = 3.92 plf
2.38 ft.
2.25 ft.
2.50 ft.
829.90 lbs
829.90 lbs
12/5/2021 3
lu = Unbraced Length = 2.375 ft.
lu/d = = 5.18
le = 2.06lu = 2.06(28.5) = 58.71 in. = 4.89 ft.  (NDS Table 3.3.3)
Rb = = 5.99
 Rb = 5.99 < 50   ➜  OK
12/5/2021 4
FbE = = 19398.89 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (900)(1.15)(1)(1)(1.3)(1)(1) = 1345.50 psi
CL =   = 0.996
Fbx' = (900)(1.15)(1)(1)(0.996)(1.3)(1)(1) = 1340.5 psi
fb = = 371.4 psi
 fb = 371.4 psi < Fbx' = 1340.5 psi  (CSI = 0.28)   ➜  OK
fv* = = 44.01 psi
 fv* = 44.01 psi < Fvx' = 207.00 psi  (CSI = 0.21)   ➜  OK
fv = = 71.67 psi
 fv = 71.67 psi < Fvx' = 207.00 psi  (CSI = 0.35)   ➜  OK
12/5/2021 5
ΔLL = = 0.01 in.
(L/d)LL = 28.50 / 0.01 = 4817
 ΔLL = 0.01 in = L/4817 < L/360   ➜  OK
ΔTL = = 0.01 in.
(L/d)TL = 28.50 / 0.01 = 3991
 ΔTL = 0.01 in = L/3991 < L/240   ➜  OK
fc⊥ = = 184.4 psi
 fc⊥ = 184.4 psi < Fc⊥x' = 625.00 psi  (CSI = 0.30)   ➜  OK
12/5/2021 6
