Grade: SP Stud
Size: 2 x 4
Design Span (L): 3.75 ft.
Clear Span: 3.50 ft.
Total Span: 4.00 ft.
Live Load: 1000 lbs
Dead Load: 75 lbs
Selfweight: 5.1 lbs
Dist. Selfweight: 1.36 plf
Total Weight: 5.4 lbs
Beam Design 2021A712
12/3/2021 1
d = 3.500 in.
A = 1.500 x 3.500 = 5.25 in.2
SP Stud 650 400 175 565 850 1300000 470000 0.55
12/3/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [5.25 x (45.00 + 3)] x (12 in./ft.)3 = 0.15 ft3
Volumespan = N[A x L] = 1 x [5.25 x 45.00] x (12 in./ft.)3 = 0.14 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 0.15 = 5.4 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 0.14 = 5.1 lbs
Distributed Self Weight (ws) = = 1.36 plf
1000 lbs
75 lbs
ws = 1.36 plf
3.75 ft.
3.50 ft.
4.00 ft.
540.22 lbs
540.22 lbs
12/3/2021 3
lu = Unbraced Length = 3.750 ft.
lu/d = = 12.86
le = 1.37lu + 3d = 1.37(45.0) + 3(3.5) = 72.15 in. = 6.01 ft.  (NDS Table 3.3.3)
Rb = = 10.59
 Rb = 10.59 < 50   ➜  OK
12/3/2021 4
Eminy' = Eminy(CM)(Ct)(Ci) = 470000(1)(1)(1) = 470000 psi
FbE = = 5025.25 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (650)(1.15)(1)(1)(1)(1)(1) = 747.50 psi
CL =   = 0.991
Fbx' = (650)(1.15)(1)(1)(0.991)(1)(1)(1) = 741.1 psi
fb = = 3958.4 psi
 fb = 3958.4 psi > Fbx' = 741.1 psi  (CSI = 5.34)   ➜  NG
fv* = = 154.19 psi
 fv* = 154.19 psi < Fvx' = 201.25 psi  (CSI = 0.77)   ➜  OK
fv = = 154.30 psi
 fv = 154.30 psi < Fvx' = 201.25 psi  (CSI = 0.77)   ➜  OK
12/3/2021 5
ΔLL =   =   = 0.27 in.
(L/d)LL = 45.00 / 0.27 = 165
 ΔLL = 0.27 in = L/165 > L/180   ➜  NG
ΔTL =   =   = 0.29 in.
(L/d)TL = 45.00 / 0.29 = 153
 ΔTL = 0.29 in = L/153 < L/120   ➜  OK
fc⊥ = = 120.0 psi
 fc⊥ = 120.0 psi < Fc⊥x' = 565.00 psi  (CSI = 0.21)   ➜  OK
12/3/2021 6
