Beam Design - X
Design Span (L): 14.00 ft.
Clear Span: 13.50 ft.
Total Span: 14.50 ft.
Live Load: 180 plf
Dead Load: 20 plf
Selfweight: 112.2 lbs
Dist. Selfweight: 8.02 plf
Total Weight: 116.2 lbs
Notes: Doublers on beams
Beam Design B Holmes GWE L9 GWE L9
1/16/2021 1
1/16/2021 2
Volumetotal = N[A x (L + lb)] = 2 x [16.88 x (168.00 + 6)] x (12 in./ft.)3 = 3.40 ft3
Volumespan = N[A x L] = 2 x [16.88 x 168.00] x (12 in./ft.)3 = 3.28 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 3.40 = 116.2 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 3.28 = 112.2 lbs
180 plf
20 plf
ws = 8.02 plf
13.50 ft.
14.50 ft.
1508.12 lbs
1508.12 lbs
1/16/2021 3
fb = = 966.4 psi
 fb = 966.4 psi < Fbx' = 1035.0 psi  (CSI = 0.93)   ➜  OK
1/16/2021 4
fv* = = 56.05 psi
 fv* = 56.05 psi < Fvx' = 207.00 psi  (CSI = 0.27)   ➜  OK
fv = = 64.72 psi
 fv = 64.72 psi < Fvx' = 207.00 psi  (CSI = 0.31)   ➜  OK
1/16/2021 5
ΔLL = = 0.27 in.
(L/d)LL = 168.00 / 0.27 = 615
 ΔLL = 0.27 in = L/615 < L/360   ➜  OK
ΔTL = = 0.32 in.
(L/d)TL = 168.00 / 0.32 = 532
 ΔTL = 0.32 in = L/532 < L/240   ➜  OK
fc⊥ = = 83.8 psi
 fc⊥ = 83.8 psi < Fc⊥x' = 625.00 psi  (CSI = 0.13)   ➜  OK
1/16/2021 6
